Hey all, I bought some HKS 264 cams (2nd hand) for my rb25det and they arrived today. Now they came in their box's with original instructions etc. I have looked over both cams ten times and I cant find a HKS stamp ANYWHERE. This to me seems wierd for such a big branded camshaft to have nothing written on it. One camshaft has U2 stamped on it one has U3. Can anyone tell me if they had the same camshafts or how to tell if they are indeed aftermarked HKS cams??
Jamie
https://www.sau.com.au/forums/topic/263411-hks-camshafts/
  • Replies 44
i dont think any cams have their brand on them..
tomei hks etc etc all are unmarked
Oh really?? Ive seen some marked hks, and was just having a read of different forums of people with my same concern. As my stock camshafts are still in the car I have nothing to compare them with.... anyone know how im going to tell?
https://www.sau.com.au/forums/topic/263411-hks-camshafts/#findComment-4507664
Call the dude and ask him, atleast the HKS ones have markings so you know, with the Tomei ones they dont have shit, so you put them in hoping you have the right ones.
Here's a question for you, on the stock camhafts, near the cam gears, you can put a spanner on it. On the HKS ones you can do the same thing half way down, the stock ones have nothing. Do yours have these?
Edited by PM-R33
https://www.sau.com.au/forums/topic/263411-hks-camshafts/#findComment-4508007
Nope mine have nothing like that...its at the end where the cam gear is....and the part of the shaft in between the lobes (where your hks is printed) is concaved on one side all the way down....whereas yours looks solid
https://www.sau.com.au/forums/topic/263411-hks-camshafts/#findComment-4508024
Hmm interesting, the stock ones have the concave....
https://www.sau.com.au/forums/topic/263411-hks-camshafts/#findComment-4508049
The HKS cams I had did not have HKS stamped on them and now my TOMEI cams also don;t have any branding stamped on them.
Ahhhh you serious? Did they have the concaved bit between the lobes?? (like in my pic) What car were they for??
https://www.sau.com.au/forums/topic/263411-hks-camshafts/#findComment-4508100
Ive just searched two different forums and they both said Genuine HKS cams will have HKS stamped on them. Who can confirm this? Im pretty sure theyd have something on them being such a massive Brand. One camshaft should say HKS and one should say 264 apparently.
https://www.sau.com.au/forums/topic/263411-hks-camshafts/#findComment-4508192
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
