  • Replies 494
Posted Images
hey i got told by a fellow SAU'er that meets happen often? anyones know of any ones coming up ? im keen to meet up with some enthusiasts, not f**kwits and go for abit of a spin :P
im on the gc but dont mind a bris run if theres a few cars involved.
NO SPEEDHUMPS UNDER ANY CIRCUMSTANCES PLZZZZ. 65mm ride height f**ks my life
Come on to the pre dyno day at EFI (Yatala) this saturday. I'm pretty sure Dan's coming along too yah? Or are you gonna start cupping EFI too!?!?!?
Is that for me? Or am I missing something I don't know coz I quite don't understand what your saying?
I would like to come, provided its not a hot day!
hey i got told by a fellow SAU'er that meets happen often? anyones know of any ones coming up ? im keen to meet up with some enthusiasts, not f**kwits and go for abit of a spin :)
Hey man :D
Me an a couple of mates have been going on little cruises the past few weeks, nothing special just good to get out and go for a drive wit a good group of ppl.
Ill post up in this thread next time we going and you can come check it out.
Sorry that I've confused you. The last 2 sentences were meant for Dan aka Danski.
The workshop starts from 10am. It cant be that hot.
Hey Brandon how was it man?
Yea it's good. Didnt see you there. You coming for the dyno day?
I'll be heading down to Seaworld this Sunday for the company's family day.
Ah k good to hear. Nah I wasnt there man I had a bit of a party wknd cause it was my bday :D
I will def be going to the dyno day though :)
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
