I've finally tracked down my fuel usage problem - the clutch fan is 'sticking' so when the revs go up, so does it - it's louder than the engine at speed! It means I'm always pushing the fan around, even at speeds that it shouldn't be...
I rang around and there doesn't seem to be a third party replacement - and the stock nissan one is $435. Has anyone got a working one who wants to sell it, or know when I can get one cheap?
Ian
I replaced the clutch fan in my R33 GTST a few months ago with an aftermarket product, so they definitely make them for R33's at least. Not sure if the R34 is the same though.
Bought mine from a place called Motor Spares here in Canberra, from memory it cost about $160.
They have a website http://www.motor-spares.com.au and pretty sure they post stuff anywhere.
Give them a call, they might be able to help you out. :blink:
JD
Give them a call, they might be able to help you out. :P
JD
thanks - I'll ring them in the morning.
Ian
OK, this will hopefully be my 2nd last post on this... I hope anyone ever looking for a cluch fan for a r33 or r34 reads it!
I rang a few after market shops, but nobody had one listed for a R34.
I rang nissan and they quoted $435 for a new one
I then rang a few wreckers, and got quotes of $150 to $170, but 'only for a R33'
I rang back nissan, they said (after checking the part numbers) that the R33 one was the SAME as the R34 one.
That was good, as I could get one from a wreckers BUT it might be as old as an early R33! So I didn't really want to risk it..
So I rang back one of 3rd party parts suppliers (http://www.motor-spares.com.au from above) and asked could they send one down from the ACT. Their quick reply was that it came from melbourne from davies craig! (part 5265).
So I rang them (03 9369 1234), and yep they have them in stock - $213 inc gst ie
http://www.daviescraig.com.au/Fan_Clutches...65-details.aspx
So after many phone calls and hassles, I'll be buying a new one for not much more than an old one from a wrecker..
Going to get it tomorrow morning, I'll report on how I go with it after I put it in, it will be interesting to see if it fixes my fuel problem.. :-)
Ian
  • 2 months later...
did it? And where is it located precisely ? I don't notice any 'roaring noise' when I hit the gas pedal or maybe I do but am assuming it's engine noise?
Just replaced the o2 sensor and AFM and still same shitty 18-20l/100km economy...city driving (lots of stop'n'go) and mostly short trips.
Edited by Delta Force
  • 2 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
