Some of my friends are photographers so they invited me to go down and take some pics.. i didnt think it'd mean i'd be standing around for hours while they do all these lighting and taking 1000000 pics and only give me like 4 LOL
i just think the pics turned out good with the scenery so i thought i'd share
Jin :)
https://www.sau.com.au/forums/topic/263605-docklands-camera-car/
i dont know.. they had these flashy thingos that kept going off.. and then they'd wait for 10seconds and then took pics. guess the last one they didnt use the flashy things haha
did they give up setting up the lights at the last pic?..he. first one turned out good.
haha, they just own camera's. Except for one guy who is a wedding photographer. He was the one who had taken the first pic.
Are your freinds photographers? or do they just own cameras? :)
The first pic is sensational.
LOL experience shines through...
Seriously I can't believe how many photos pro photographers take, and then cull 99% of them and brush up the remainder in photoshop for hours. A lot more work to it than I expected. They have to have huge-ass multi-terabyte HDDs as well when each photo is like 30meg in RAW or >100meg in uncompressed TIFF.
the 1st photo is friggen awesome it looks unreal. :P
in the last 2 photos are you parked on the foot path?
yes, in the last two photos im on the footpath. security came but they didnt care. and in the first one i was parked in the middle of the road.. the AFP came.. but they didnt car either.. it was my lucky night :laugh:
yes, in the last two photos im on the footpath. security came but they didnt care. and in the first one i was parked in the middle of the road.. the AFP came.. but they didnt car either.. it was my lucky night :rant:
I asked coz me and a mate went down there to take some photos about 2 months ago and i also parked it on the footpath maybe 10m or so behind to the right of where you parked.
also there is a road where the tram goes along and there is a walkthrough corridor through the shops and it has a lot of lights there, i wanted to drive up inside the walkway and get some photos, but it was starting to rain and there was at least 2 cameras pointing towards the walkway, so we bailed :laugh:
and i still have not got the photos off him yet, damn people who take photos can be so lazy :P
also there is a road where the tram goes along and there is a walkthrough corridor through the shops and it has a lot of lights there, i wanted to drive up inside the walkway and get some photos, but it was starting to rain and there was at least 2 cameras pointing towards the walkway, so we bailed :)
and i still have not got the photos off him yet, damn people who take photos can be so lazy :cheers:
hahaha.. so true man. they're lazy lazy people.
Very nice pics man, especially the first one.
The angle on the last one is awesome, but only if the lighting was a bit better your car would look mad!
thanks man. yeah i wish there was abit more lighting. would've been good.
and thank you to (OO)SKYLINE(OO) and ujin for the kind words :cheers:
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
