  • Replies 505
Posted Images
Kellie this sounds like a great idea, bout time someone got the ball rolling! I think SAUSA is the best way to go, considering the resources at hand. Too bad i wont be able to make the meeting next wednesday, had a bit to do with CCCSA (Chrysler Car Club of SA) a fewe years back but if i can help out in any way i will
one thing to ponder, if all the regulars go off to this club, what will become SAU SA? a ghost town? or will it be a extension of SAU?
Wednesday, hmmm guess I missed out already..lol didnt get a chance to load up MSN.
SAU will never become a ghost town! :)
Omg I hope you guys do decide to go with SAU-SA and can design different looking stickers if worried people wont be able to tell the difference between club and normal SAU..All to be discussed ion the meetings
So exciting I have been waiting a long time to see this happen and wish you guys all the best.. :rant:
Shoot me a PM if you need any help Kel and Freinds!
Will be visiting SA in the coming months too!!
thinking about this alot last night, im glad you have chosen the SAU:SA path Kel, im happy to help out but cant make the meeting.
Pending Pranks approval of course, i think this can work. Regarding stickers, if we want to seperate outselves, i was thinking of something along the lines of:
more refined of course, and maybe the S in "SA" in white.
Those who are interested in motorsport you can't beat Nissan Datsun Car Club (NDCCSA). $50 single or family membership is damn cheap CAMS affiliated, might be worth trying to structure the membership fees around NDCCSA.
http://www.nissandatsuncarclubsa.com/
May be worth while looking in to becoming affiliated with MSCA as its an invaluable addition to a car club. Makes for a great day racing against some exotics, great fun handing it to a dodge viper!! :)
http://www.mscasa.com/
http://www.mscasa.com/results/2009/results_round1.html
Some very quick cars out there.
IMO no affiliation with MSCA = loose. :rant:
--- Hope all goes well with the car club. The biggest issue is the liability side of things on cruises etc. Be careful make sure you cover yo ass if its more of a social club than motorsport.
Edited by TheRogue
Damo that look freakin awsome :)
awesome logo Damo, i was thinking something similar to the SAU logo but with the 'A' to make SA to the right of the 'S'
and as far as costs go, someone good with maths should work it out :) enough to cover events etc
Good idea on the logo Damo. How would the S in SA look as blue? IMO it would look better. :kiss:
Yep i was thinking of that as a variation as well.
Keen as to hear from Prank!
a club is going to need someone that can spell, use grammar, and also be a nice person in general.
as for the people saying 'good to get the ball rolling', im pretty sure the sausa ball has been rolling for a long time, it just hasnt taken anyone out along the way.
and if your not here to keep the ball rolling, theres the door.
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
