Hey guys,
Got an r34, have spent the last few hours searching with no results so I am creating a new topic.
Firstly, I love the look of all 4 taillights on my r34 lighting up. Is there any way i can rewire the lights so when the brakes are applied all 4 lights, light up?? I have seen this done before and would love a guide, or any help in how I can go about doing this.
Secondly, I Installed a new headunit two weeks ago, and then last week pulled the console out again, to re paint over the factory centre console paint. Both of these times i scratched the outter centre console pretty badly. (around the centre console) im sure you all know where I mean as looking through pictures of other 34's They all seem to be scratched. How do i go about fixing this?? Is there anyway I can retrim/paint/cover this?? what is everyones opinion on how to go about fixing this?
Thanks for reading,
Any help/opinions at all will be greatly appreciated.
Nathan.
Hey guys,
Thanks for reading,
Nathan.
as far as i can tell you cant fix the scratches, my only suggestion is to have it re-trimmed if it bothers you that badly, that or buy new trim pieces that are un-scratched, unfortunatly not a lot of options
What could it be retrimmed with? I'm not sure what the material actually is?
What do you think these pieces are worth in decent condition?
wouldnt have a clue, considered buying some and having a go at re-trimming them myself with a nice material in a colour to match the rest of the interior.
Try Nisswreck
Rush how could you retrim it considering its like a plastic??
Nuffsaid have you got any info on how to do it at all?
a materail/fabric glue spread evently over the surface should hold the material in place nicely, let it dry for a while and put it back in the car
I believe the plastic surround the whole area ,you can order it from Nissan , not sure on the price, i know Vic member Ashneel is looking into this exact thing as well, i have asked him to get me a price as well.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
