ok, atm I have my car.
the front bar is on, but ****ed after i let my friend drive it, and he didnt know how to enter driveways...
Im also looking for a trust airpod and attachment and a nice fmic set up.
but i need insurance, beacuse I dont want to lose my car, I'm 21 had 8 speeding tickets in the last 6 years, and had my license suspensed once(the new rule).
I'm just wondering wheres the best places to go and whats the best value for money. like I dont want chrome pipes for my fmic, i'd rather black, but a chrome fmic.
my drivers door window motor is now ****ed from going up and down too much, so i'll have to replace that also.
and b4 i got my car service my car did 80 in first and then 135 in second, now it only goes to 60-65 and then seems like its trying to get more air. and in second only gets to 100. this is good for me, but I would rather a car taht works properly then not.
basically im bored sitting at home, and would rahter spend money on my car :D
https://www.sau.com.au/forums/topic/26389-my-car/
thats at stock psi also, I dont know what happened and chaos has seen my car go :D
so I'm trying to think what could have happened, can you reduce the turbo psi from stock to lower? or can new spark plugs do something?
my car has a rev limiter of 7000 but not speed limited(this is good so I cant over rev.)
so, maybe i need to get it tuned or something. dad doesnt want to help, he believes my car goes fast enough as it is, and that he doesnt want me to loose my license again...
https://www.sau.com.au/forums/topic/26389-my-car/#findComment-559440
greg have u tried taking the airbox off?? maybe thats why it seems its trying to suck more air in cause i noticed last time u had one on.
insurance....well with ur history you will struggle to get it.
I'd say go with a 400R front bar or garage ***ui or something like that (NA_R33 has one) and this have a large section in the front for a front mount.
https://www.sau.com.au/forums/topic/26389-my-car/#findComment-559454
nah new clutch, once i bought it from autoshop the clutch was over trightened and they had burnt the **** outter it, i got a new one the next day, some dakin perforanmce clutch for 900 fitted, was quoted other places for $1200. the clutch is fine, the only problem i have is the air filter is stock and the sponge is shit its almost about to fall apart(some rips in it) so I'm going to either get a panel air filter, or waste some money on a pod and make some air box thingy :D
at the service, i got new plugs, the mud outta the radirator(this didnt make the car heat up at all for some reason :D and new oils and shit like that. I run my car only on ulimate, I would get racq to tow me to a bp if i ran out of fuel in front of a shell :D
i check the water and oil regualy and would rather be saef then sorry. I also have to find somewhere that will lathe back my disc, or maybe buy some slotted ones :D
and imm thinking of getting my license back for night work, because i make 300 more a week doing nights. I THINK i could drive to and from work properly and that I will slow down on the open roads. speed kills those that dont look in their mirrors...
https://www.sau.com.au/forums/topic/26389-my-car/#findComment-559640
Bwahahahaha! Funny. I'm a BP only man too.
I got my front discs machined at Global down here on the coast. Removed them myself, drove there in my shitter, had lunch, went back, all done, $30. Still want DBA rotors tho...
Slowing down in a Skyline is a figment of your imagination... :D
And aint that the truth...
https://www.sau.com.au/forums/topic/26389-my-car/#findComment-559656
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
