Hey guys,
Sorry for the Noob question. Have searched this but cannot find what i need.
Im currently installin a Z32 AFM with Plug onto my Series 2 RB25.
Im running stock ECU, would this be a problem with the Z32? i have a PFC but am waitin to install it for tuning etc.
Now the series 2 have 3 wires in the stock harness. Z32 have 4. Im assuming the 4th is for Ground. Do you wire this into the chassis somewhere?
And do you do this for the '12v Ground' or just 'Ground', as there are 2 types of ground with the Z32. I dont want to keep cutting the wires after hookin up wrong wires.
Can anyone help me with the correct wiring for a Series 2. There have been plenty done/explanined for series 1 or R32. But cant find anything on Series 2.
Thnks guyz
https://www.sau.com.au/forums/topic/264147-z32-afm-install/
hi
the z32 will not run on the stock ecu so dont bother
but when it comes time to wire it up you join the ground wires
ie on the Z32 there are two ground wires one is for signal ground and the other is just ground
on the R33 S2 loom you have one ground wire, so you just join them all together
but dont try it with the stock ecu - it no worky and will run like a whore
https://www.sau.com.au/forums/topic/264147-z32-afm-install/#findComment-4518165
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
