I'm selling an Apexi Power FC for a R33 GTST.
Comes with hand controller.
It has been used, but in good condition.
$1800- plus postage
Located in Melbourne :blink:
will u take 1200 delivered, 1800 plus post is just way too much
you recon all the ebay ones you see at over $1600 actually sell for that much?????
besides there sold as new or refurbished and certified by apexi.
never seen a used one get more than $1200 and ive been looking for a very long time...
2. No price debates - put simply if you do not agree with the price being asked, do not comment on the thread. If you believe the seller is asking too much then either pm the thread starter or dont buy the items advertised - simple.
There is to be no "My cousin can get it for much less" or "Your asking too much" comments
Again comments such as the above will be deleted and if users persist in posting such comments, a warning will be issued
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
