hey guys n girls ive wrecked one of my 32s, ive still got heaps of shit left over
engine cross member $100
front lower control arms $ 100
upper arms new nolothane bushes $ 50
mint vicous lsd $150
Mint manual tailshaft $100
axels $70 for the pair
5 stud hubs $100
mint boot lid, white, no spoiler $ 70
passanger and drivers doors with petty much everything $100 each
dash cluster 180 xxx $ 80
interior eg front rear seats $150
extreme 6 puk clutch, still fine.. about 50-60% meat on it.. $150
r33 rb25de head $450 has new exhaust studs
type m stockl front and rear bumper ok condition $100 bucks for both
custom castor rods with new nolothane bushes $70
stocko suspension $ 150
front coilovers.. unknown brand no leaks $100 bucks
ive got heaps of random stuff laying around so if you need something drop me a pm or msg me on 0433 690 019
im in morphett vale, adelaide
cheers, Nathan
Edited by natoe aka slw 031
  • Replies 41
  • 4 weeks later...
hey mate, im very interested in both doors if they have side intrusion bars fitted. and if you have front guards with indicators im interested in them to.
Pm or call/sms 0422 034 450 as ill pretty much take them if they ahve the intrusion bars fitted.
Ryan
HI I'm looking for a R32 roofliner, Boot Panels, L/R front Pillar Covers, L/R rear window surrounds and the two Panels that go below them next to the seat. Can you help
Yo dude,define "front coilovers",just got em today,they are just stock springs on an upgraded shocker
lol what do you mean?? they are the older style coilover wich is cerclip adjustable.. and they are not stock springs! they are twice the thickness of the standard coils.. and they are 3 times as stiff!
parts that are left..
5 stud hubs $100
rear seats mint cond $ 30 bucks
cheers, Nathan
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
