I must firstly confess I have little knowlege of the V series of skylines - so I come in search of advice.
A friend of mine has just picked up his 2004 V35 350GT coupe with the six speed manual and is looking at the twin turbo and supercharger kits that are available.
One of the big questions though is how strong the stock gearbox is, I have searched for information and found vague torque limits. Does anyone know exactly how strong the gearboxes are - reports tend to vary wildly.
Any info or links would be appreciated.
Having busted one (6M) within weeks of purchase....and now having a new one...I know this....they are heavy bloody things, even when on a trolley! lol!
They are noisy/rattly bloody things too!...but they're strong, and should handle nominal power upgrades.....my mechanic agrees.
As for that diff?.....pffffft...who knows?
Hardly 'tech' words,..but hey, who gives a faaark!
Strong... but you busted it... can you please explain a bit further?
What went wrong and how do you imagine that happened?
Was a new one costly?
7000rpm launches with slicks on, flat changes etc :D
yes.....a little something like that...
and (incorrectly) attempting to engage reverse (by accident) at freeway speeds...(successfully).
  • 1 month later...
My 04 model has a feature to prevent engaging reverse. You have to push the gearknob down to allow reverse to be engaged, doesn't yours have that?
I just cringed reading that. OUCH! Reading something like that to me was like imagining getting kicked in the crotch.
I heard a similar story from an indo driving a DC5R downshifting from 6th to 4th but was a bit too excited and hit 2nd... rev, bang.
On another note a bit of chattering is normal from these boxes? And a slight chatter when turning the ignition off? Its def the box because there is nothing with the clutch in.
There's a dude trying to sell a 535rwkW V35 on Carsales (Carl). See what he's done to his box, because he's had that setup for a while and he hasn't grenaded the gearbox yet.
The 03 boxes have a reputation for breaking (but that's even with NA bolt-on specs) but there are guys who've gone FI and tracked their cars (250-320rwkW) for a few years without breaking them. It sounds more like dodgy QC rather than an inherent design fault.
anyone?
A mate of mine was telling me about a BMW track day his boss went to. Flying down the main straight of EC in an M3, tried to go from 4th to 3rd to prepare for Turn 1, hit the gate and pushed harder, and found 1st.
I only got symptoms similar to what you're describing when I fitted a JUN flywheel in my first box. Stock flywheel/clutch it didn't do it.
I did a Nismo clutch/flywheel when I fitted a second 'box, and it's the same now. A little rattle on idle with the clutch out, which stops when I clutch in. It only happens when the driveline is warm though.
I'm not sure if the Nismo flywheel is dual mass or not, but I heard it was. That might be the flywheel for a single plate clutch instead though.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
