^^^ How True! :yes:
THE IMPORTANT THING TO NOTE IS THAT THE ASSEMBLY POINT IS NOW...
"SYDNEY INTERNATIONAL REGATTA CENTRE" 9.30-10.30am
Old Castlereagh Road at Castlereagh ie North Penrith
great brochure.
I am concerned nobody will have a chance at winning those award categories so, can we add..
"Information Overload" awarded to the cockpit that looks most like a flight deck
"Auto Wash King" awarded to the car with the most visible cobweb scratching
"Pimpin aint easy" awarded to anything with 20" wheels, spinners, etc
"Bozozuko master" awarded to anything, well, Bozozuko
"Most incomprehensible ICE" awarded to the car with the most original JDM navi and stereo trinkets with no english language modes
"Least Likely To Idle" awarded to the car with the least stable idle
"Petroleum Liberation" awarded to the car pumping the most unburned fuel out the tail pipe (judged by number of seconds required to create actual tears)
"Defect King" awarded, by someone in cop fancy dress, to the car with the most clearly visible/audible defectable items
This way I feel that most attendees will believe they have a shot at at least one award on the day :yes:
well actually you deserve it too Nick.
...been told you've been whispering in the ears of Hills M/S, Powerplay, Croydon RD etc
It starts at Regatta ctr Penrith right? 9.30am right?
Are you thinking of coming Delta Force?
By all means just turn up, i'll add your name to the attendance list.
Check out the thread for any other details:
10th Anniversary R34 Cruise
^^^...maybe a tad less than 100 leaving Sydney International Regatta Ctr at Penrith
Congregating at around 9.30
Briefing at 10.15
ETD at 10.30
ETA Mt Wilson 12 Noon
Good to have you in your 'black beauty' Denis
ZOMG !#!$!$$ 100 ??? you serious ? Holy crapola batman .. I thought it's gonna be like 20 cars max. Man this thing will be massive ;) Can't wait!
I prefer to call 'her' The Reaper :D
great brochure.
This way I feel that most attendees will believe they have a shot at at least one award on the day :P
Hahaha, very good post!
Ill be going for the least likely to idle and the petrol liberation categories. Stand behind my car to see why.
great brochure.
Yeh I lmao ...
...but Skaifie won't sign 'em ! ! !
If weather is a bit drizzly, we're still "ON"
If it's rain, the Event will be delayed ONE week.
Wet weather up at Mt Wilson will mean that the Demonstration by Sensei Hans and Sensei Dave after lunch will be cancelled due to safety reasons. :D
On sunday cause i have to drive passed the mount wilson turn off on the way 2 pick nick up ill see wat the weather is doing on my way passed and let every1 know when i get down there or when i get coverage.
Please see attached. Any questions just post them up here. Print and bring it along with you if you wish.
cheers
Eugene
hi eugene i will be coming if it's not raining thanks bill (eat.430) blk 99 v spec
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
