  • Replies 45
Pretty sure Ace broke his legs over the past weekend, so you may be out of luck there. Pretty gay
ahh shit that sucks big time... im sure he could still do it from a wheelchair :)
Turbo rolla nice :)
put a hairdrier on your rolla too ;)
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4532164
For about $50 you could get a nice smallish intercooler to plumb into it. I couldn't stand running any forced induction without an intercooler. :P
i would for the awesomeness ... but its not the best idea
cos fuel vapor mixes from the carby into the induction system, one lil carby backfire could blow the front of the rolla a new a$$
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4539927
But thats more of a concern for a suck-thru system. Your blow-thru system could take the intercooler between the turbo and carby. :P
Edited by RubyRS4
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4540054
picked up those drift gauges from vince this arvo (boost, water temp and oil pressure) pretty keen to get em in the rolla.
they are pretty sexy n im tempted to put em in the 32 lol.
only reason i dont think i will is i currently have boost, water temp and oil temp... im not heaps keen on replacing my oil temp gauge with oil pressure.
wish me luck butchering the dash to get the gauges in lol
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4543426
Doesn't happen on blowthrough setups, 10yrs ago i had the same setup on a ke10
before going efi, the biggest problem you have with the stupid things is carby sealing
on hi-boost(16+psi), mine use to blow out carby gaskets all the time.
cheers
darren
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4543647
cheers
darren
it can happen, just far less likely than it is with draw through.. while the carby is backfiring I'm not even going to consider it lol.
I blew carb gaskets on the old carb that was only at 8psi too. the weber I have now should handle the 10psi I plan to run nicely
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4544017
I still have a custom fab plenum lying around for an L16, L18 or L20 motor! :thumbsup:
Might find a nice tidy auto 120Y, drop in an L20, Mahl pistons and Waggot cam and supercharge the dam thing with EFI. :)
Edited by RubyRS4
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4563160
I still have a custom fab plenum lying around for an L16, L18 or L20 motor! :D
Might find a nice tidy auto 120Y, drop in an L20, Mahl pistons and Waggot cam and supercharge the dam thing with EFI. :blush:
If you drop in an L16...using stanza struts as a brake upgrade, it will be a legal conversion... :sick: ...then blow it.....i miss my datto's....had 4 different ones back in the day
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4563191
If you drop in an L16...using stanza struts as a brake upgrade, it will be a legal conversion... :D ...then blow it.....i miss my datto's....had 4 different ones back in the day
I've had a total of 6 or 7 dattos over the years. Some of the most easy modded and fun cars ever. Parts interchangability is huge.
https://www.sau.com.au/forums/topic/264718-my-rolla/page/2/#findComment-4563248
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
