I'd go 1000's, straight up.
i would buddy but theres like a 500bux differnece in price, bitch of a cold start and exhaust idle. =[
Would 1000cc Sards be ok to Run a 26/30 on E85 pushing 400-500kw?
Sorry to hijack
theyd be fine, only reason im asking is maybe they might be to overkill.
Edited by VB-
I went with 750's and now looking at having to move them on for something bigger - given hindshight I would have saved money if I'd gone 1000's first time around.
What ecu are you using to be concerned about injector control?
well ive always planned to use the PFC D jetro.......but some have raised the question about Haltech.....problem is i dont think they have a plug and play unit =[
I would go 1000cc, low impedance. Trying to make motor with 1000cc, high impedance, injectors idle would be an absolute prick.
The reaction time of a low impedance injector is a lot faster, hence the motor will idle more smoothly, than if you were to use a high impedance injector.
im in the same boat, in the sard range there are 2 options:
1. black top/orange tip, lag time 1m/s
2. light blue top/green tip, lag time .85m/s
is the 1st injector low impedence you are referring to?
i run 1000cc sards and bigger cams than mentioned and idle is no problem at all. cold start idle was never the greatest but i aint running the idle air control valve any more and never really cared as it wasnt a daily driver. I had to keep the revs up a touch for 30 secs and then it idled itself fine, dont think this is the injectors fault though.
1000's in a 14mm fuel rail. 1600's if you want to run e85. i have 1000's and at 376kw they are on 75-80% cheaper to get 1 set not having to buy smaller ones only to run out of RELIABLE headroom..
1000's idle perfect, just depends on your tune,, oh and ecu
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
