me and a friend in a problematic NA supra needs servicing .. any suggestions again?
tried PVP .. they were ok, excellent customer service
others i know of are rpm, tilbrook, turbo tune ... but i dont' want to go to these places .. due to $$$ and we just want a good service not exactly wanna tune a powerfc :) ... just wanna get an oil change and get all the fluids checked as well as the checking piping for leaks ..
thats about all i know, i was told to go to someone down at marion but i forgot who told me...
thanks
https://www.sau.com.au/forums/topic/26482-another-service/
Originally posted by RSR33
He has done a fair amount of work on my cars and only charges me $35 per hour.
thats you he charges $35 per hour if i went in it may be a different story unless this is a set rate. btw how much can a tuner charge per hour or does it depend on what you want done ie. dyno tuning/road tuning/power fc tuning. im just curious as i havnt had my care tuned before ever :D
https://www.sau.com.au/forums/topic/26482-another-service/#findComment-562416
Originally posted by Steve
If you just want to change the oil, perhaps you should do it yourself???  You could buy the oil from coles and it would be even cheaper.
Think of all the money you can save:)
yea I think we hav half a 750ml canola oil left over from the BBQ if anyone wants to mix and match
https://www.sau.com.au/forums/topic/26482-another-service/#findComment-562587
Yeah, special price for you on the canola oil hippy:D
some dynos charge up to around $150 per hour for the first hour, then $80-$100 there after - so they can be pretty bloody expensive.
I honestly believe that if you pay extra and get the job done right the first time, it will be way cheaper than getting an average tune, then having to take the car into someone else to get it done again.
Hippy, unless you want to have the car tuned, just do the service yourself - you can quite easily change engine oil, dif and trans oil yourself - where you would be paying someone $50 per hour in labour. do a good visual inspection of all your hoses, check fan belt tension, check your lights, washers, wipers, etc. Even bleed the brakes yourself (good to do at least once a year, just dont use dot5 fluid which will cause major probs with your seals, use dot 5.1:)) Plugs arent a major problem either, change them yourself too.
If you want the car tune, get it done after you have done all the above, and it will save you a heap of dollars.
and buy the canola oil:p
https://www.sau.com.au/forums/topic/26482-another-service/#findComment-562898
Well steve i have 1000kms till i have to change the oil. Oil and filter are piss easy, however i want to change the Diff oil cos the diff open wheels so im hoping changin the fluid might help abit.
Also is there any need to change plugs, cos my car is firing beautfully, so i dont see the need to change them.
Finally do i just do visual checks of other things like coolant clutch and p/s fluids?
Thanks
https://www.sau.com.au/forums/topic/26482-another-service/#findComment-562928
Dean, do you know what plugs you have? If you have coppers, it would be worth changing them every 10,000kms - if you are unsure, pull them and have a look.
Definately check all your fluid levels, also have a good look around the engine bay for any leaks, same time, check around all the hoses and lines for brakes, clutch, cooling etc for any leaks. And check your brake pads.
I havent changed the diff oil on the R33, I will have a closer look at it tonight. Usually you will have two bolts, a drain and fill. Just take the drain bolt out and drain fully (let is stand for a while). Check for metal filings in the oil, as this can be a good indicator of problems - although all diffs will drop a few filings, just like gear boxes. Once the diff has drained fully, replace the bung and remove the fill bung, just fill to its level with the bung (unless there is a recommended fill volume?) sorry I am not 100% on that one - think I may need to check:)
hippy, yes someone can do it for you - morpowa:p
https://www.sau.com.au/forums/topic/26482-another-service/#findComment-563221
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
