So after recent family events I HAVE to part out and sell my 32, so most things will go and ill keep the things that possibly go on my next car for in the near future, so here goes...
Red Top SR20DET - $1200 it comes with Stock Intake, Turbo Manifold, Injectors, Loom, No ecu or Stock Coils, N/A Cams, NISMO Thermostat, Flywheel was comp tested at 145 across all four before I bought it off Erin from JDM GARAGE etc
SR20 Greddy Plenum - $300
R32 100mm GTR Cooler - $300
S13 Engine Dampener - $30
SR20 NISMO Clutch - $200
R32 HSD Coilovers 10/8 - $650
R32 Front Camber Bushes - $200
R32 Cusco Front Strut Brace - $150
R32/S13 Cusco Rear Strut Brace - $150
S13 Rear Toe Arms - $150
R32 Whiteline Adjustable Front SwayBar For R32 - $150
R32GTR Bonnet - $300 Comes with GTR Locking mechcanism
R32GTR Gaurds - $200 Each
R32GTR Front Bar - $350
R32GTR Grill - $100
R32GTR Indicators - $100 For the pair
R32 Non Projector Headlights - $200
Drift Button - $10
Welded R200 Diff - $150
HICAS Lock Bar - $100
R32/S13 Rear Camber Arms - $100
R32 GTR Fuel Pump - $150
APEXi AVCR - $350
Polly Urethane Subframe Bushes - $100
Gutted Cat - $20
3in Mild Steel De-Cat Pipe - $50
D1 Spec Oil Catch Can with Rubber Hose's - $50
3in Dump pipe to Cat with plumbed Screamer - $150
As for the shell ill let it go for $3500 and it includes;
Full Boot interior - And I mean everything inclueding Space Saver Jack Tool Bag, Trimming, Carpet EVERYTHING
Full Cabin Interior - Minus Front seats as im keeping them but a bonus HKS Turbo Timer and APEXi AVCR is left in there
HSD Coilovers 10/8
Rear Camber Arms
HICAS Lock Bar
R33 GTS-T Wheels x2
No Front Panels or Lights - But pending if you want gaurds or what ever other panels on it can be aranged
Half a Tank of Fuel
R32 GTR Fuel Pump
No steering rack
No Castor Rods
Full 5 Stud Hubs all round
Full Brakes all round - with near new rotors and pads all round
Brake Booster and Master
Clutch Master and Lines
All HICAS Removed
Full Glass Windows All round
Welded R200 Diff
Kenwood speakers all round
So all you need to do is wack in a motor, box, loom, steering rack and you got a running car with coilovers and a diff to get you sliding!
Enjoy!
https://www.sau.com.au/forums/topic/264852-parting-out-32-sale/
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
