Brand new Wolf 3d plug in and Apexi avcr $1400
Air temp comp goes some way, better than the power fc in that regard, but as Paul says, I just want that added comfort - other than dud fuel, you could get fouled plugs, esp if you are running colder heat range - I really is comforting to know that IF it happens, you will be aware of it before damage is done - I know alot of people do without them, but now that I am used to it, I wouldnt have it any other way.
Just think Paul, if you had a decent knock sensor, you could run your 411rwhp without worry:D
  • Replies 59
Oh, and please dont think I am having a go at Wolf, from the sounds it is a bloody awesome ECU and goes alot further than the power fc - but I have spoken to some people in SA, including the rep, and they either didnt know much about the ecu, or didnt want to touch it.
If I still lived in the west, there would probably be a power fc for sale;)
Maybe some people here in SA should organise a group buy and get Steve to come over to fit, set up and tune them???? Not as silly as it sounds.
If there were people interested, I would definately be looking at an upgrade - but I want a knock sensor!
Guest darrinspencer
Thanks guy's for the imput. I bought the Wolf ecu last Friday or should i say i stole it for $800 brand new in the box.
The guy i bought it from had spent approx $20,000 grand on his car with a speed shop in Brisbane, and got taken for a ride.
I do not think they are that "Fast and Furious" after all. I believe the courts will be sorting that out.
I have not bought the Apexi avcr as it is still on his car and is needed to keep it running at this stage. He will converting the car back to standard.
So as i understand it, I do not need it? (AVCR) Does the wolf use the factory bleed valve to control boost levels?
Bl4cK32, sell the AVCR, and recoupe some of the cost:)
I spoke to Mildrens a few months ago, they said they didnt know much about the Wolf for R33, and to check with SST! Hopefully they have it sorted now.
And I just thought of a really good reason to buy wolf - one that everyone has missed, Sequential Idle - sounds tuff as hell (really, really tuff), and it even cools the engine:)
Gotta have my intake of rice with the Avcr - i'll keep it and run the wolf with boost turned off ;)
Mildrens reckon it'd be about 500 for the tuning. Joel spoke to them so he knows more than me :D They only released the 32 version as well as the r33 in like April? Both would be similar to tune I assume?
Rotational idle? What is that?
I've only every heard of stepper motor control which is apparently a good feature for ecu's.
EDIT: I forgot to mention the blokes from Wolf have been watching this thread.. :D
Rotational idle wouldn't be that hard to implement would it? If they put that in along with a knock sensor that would be a very good reason to upgrade from PowerFC to Wolf :D
Edit: Hmm, in the thread linked to below, GTS-t VSPEC says the Wolf does support rotational idle? So does it or doesn't it?
JimX, It's not a direct feature that Wolf advertise, but it is something that can be implemented with a decent tuner, Steve has even setup a couple ferraris to run rotational idle:D
It's good that Wolf are following this thread, we'd love to give them some positive feedback and encourage them to add features which will make choosing the Wolf even more desirable:D
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
