because I put it there! :thumbsup:
cams aren't modded - the top comment was in jest of nissan having a whinge about the warranty of these things.
as for tricks of trade. call me mean, but I spent 12hrs under this car and for now the info is not going to be public knowlegede.
Chris,
People on the UK GTR site (www.gtr.co.uk) have also been looking at instaling satnav on the Euro spec cars. Did you use a separate sat nav that just output to the screen in the car or did you tap into the GPS that is installed in all the cars (even non sat nav ones)?
cheers
see above post :)
I'm not trying to be a hard arse here. I simply spent a LOT of time under this car and for now the information stays with me.
I will say this - if you tap the exisxting system you will screw up the lap timer and clock functions as those are GPS derived.
see above post :P
Chris
Was hooking up the ipod any easier
not looking for how to do it
Just wondering if its an option ?
Is there a line in?
Cheers for any info
no line in option in the ADM car. Ipod was FM based. (alpine AX10.) I'm working on a ipod solution for them but don't hold your breath.
I'm also chasing schematics for the unit thats in there (I have the model info here.) so I can work out the line/video in stuff.
Thanks for the info
I still cant fathom why they removed the line in option
For anyone slightly stupid like me I went and got some more info from Adam at Stylyn regarding what's exactly involved in doing everything and what you are actually getting.
As it stands right now the Sat / Nav and Front camera will be operated by switches that will be put into the car under the "R Mode" switches (so above where you put a cd in). You won't be able to see them but they will be an addition to the car. Also - the Sat Nav is technically a stand alone unit (like a Garman) so the screen will only be for viewing. You will need a seperate remote to enter data etc - can't use the touch screen etc like in the US / JDM cars.
The reversing camera will come on as soon as the car is put into reverse so there are no extra switches.
The iPod as mentioned is currently going to be a hard-wired FM transmitter. Again the unit will have to be mounted somewhere you can see it (and it is also controlled by another remote). The iPod cable can be put into the glovebox but the fact is it is still an FM transmitter.
For prices you are looking at around $250 for the iPod stuff and around $4K for the Nav and Cameras.
the Ipod price is wrong :blink: it was $299 for the unit.
may as well mention the rest of what adam told you as well :)
that part I'm heavily involved in. if you decide to do the car then you will meet me as I'll probably be the other person along side adam working on it.
  • 2 months later...
ok we have made a revision to this.
the activation switches are now a touch switch. no physical switch to push, no holes in panels - touch one area and the OEM system turns off and the NAVI takes over. touch another area and the FWD camera comes into play.
Edited by Chris Rogers
see above post :P
i would keep it to myself too.
......... Nice to meet ya by the way! (H8 TAX)
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
