Hi guys
thinking of selling my rims...
chasing 20" rims now and going with a different look.
My rims i have had them on the car since the end of December.
Not a single scratch or mark, gutter rash etc on any rim.
Rims sit very flush with the guards. The rear is super flush. touch of poke. the front if running camber like i did for a bit more of an agressive look need 10mm spacer to be flush but if not running any camber will sit flush.
Current setup the rims + tyres do not rub on the car.
Details:
Volk GTS in Titanium Gunmetal Finish
Front: 19 x 9.5 +17 (265/30/19 Dunlop SP Sport MAXX 90% Tread)
Rear: 19 x 10.5 +17 (295/30/19 Michelin Pilot Sport II 70% Tread)
These rims WILL clear the brembo brakes
The Tyres on the front cost me $600 each and the rear $800 each = TOTAL $2800 NEW
Todays Exchange Rate as well as shipping on the rims will set you back around $5000 with a 3 month wait minimum
Center Caps - add another $200
TOTAL cost if you were to buy it today yourself new - $8000
Asking price - $6000
Here are some pics, will try get some better ones soon. Any of you guys coming to the meetup next month can see them in person if your interested, or shoot me a pm.
cheers
-mark
https://www.sau.com.au/forums/topic/265213-eoi-volk-gts-19-x-95-17-19-x-105-17/
hey mate - yeh i know they are technically 2nd hand, but if you come and see them, you might as well pack them up and sell them as new anyway. not a single mark on them.
on another note....
will take offers for the lot
will sell for less without the tyres - make an offer
-mark
  • 3 weeks later...
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
