  • Replies 51
Hi guys.
Just came here looking for some decent suggestions on P-Plate legal cars. I want something that looks nice and has a bit of grunt too for around the $10k mark. I've been looking at N/A R32's and new model Preludes, but I'm really unsure.
Thanks guys.
NA R32's are very, very rare, and of the few that you'll find they'll be in such poor condition it's not worth it.
R33 NA's are everywhere, and perfect for your price range.
You'll also find NA 300zx's, NA S13s, older Impreza's, Soarers, Beamers, and as you mentioned Preludes.
Personally, R33's are an awesome first car, and probably the most reliable of above mentioned.
Hi guys.
Thanks guys.
http://www.overclockers.com.au/wiki/Fun_P_plate_legal_cars
That list is a little dated, so the prices are going to be slightly cheaper.
Get a corolla... zippy and awesome on fuel.
They are zippy and good on fuel and you'll never find a more reliable car. But at the same time I've never liked small cars, they always seem to be working hard. I've always prefered to lazy torque of a six, driving up to sydney feels so good to be able to just reach 80, put it in 5th and the car just pulls itself up the hill (coming from Wollongong). But at the same time nothing makes you feel more like a rally driver than having a 2litre four screaming while going through the twisties.
Edited by JarRah
R31 5 speed. quick enough for 1st car, fun, tons of parts, cheap as chips....
Who needs a 10k first car?
R31 - 1500
Minispool - 100
advance timing, good service etc
Hours of fun for the whole family :)
Your 1st car needs to be something cheap you'll never forget, be a load of fun & that wont send you broke if you wack it.
My answer to your question is the following:
Series 3 Manual R31 GXE Wagon with:
-4:11's
-H/D Clutch
-Minispool
-Shortened shocks with custom stiff springs
-BBS 17s all round
-30mm bolt on spaces with bolt on flared guards
-Mattress in the back for your mrs/random girls :)
I had a similar setup VN wagon, and it will be one car il never forget. ;)
Edited by Dean_HR31
They are some seriously boring suggestions for a first car... lol
Take my advice & ull have stories to tell the kids one day lol
The corolla is a boring idea, the SSS is pretty good. Otherwise he could just find a VP commodore slap some stockies on the rear and save the other $7000 for the diff replacements and traffic fines.
You dont need a mattress in the back of wagon for ya missus or ya best mates little sister there are many places you can go for that sort of thing.
Thanks for the suggestions guys, I'll start looking around at all of them, and see what's available on carsales etc.
i will have a n/a r32 up for sale soon once i fix up the paint a little and get off my ps it will be in pretty good condition.
And throw some pics up mate so I can have a look see. That'd be great.
Also, keep the suggestions coming guys.
Thanks.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
