Hi guys,
Im sure this has been covered somewhere but i couldnt locate a thread.
Just wondering if aftermarket xenon HID kits damage the headlight or the lens on R33's? I have a series 1 GTR and was considering replacing the standard headlights with HID's but am unsure if it will destroy my headlights over time or discolour the lenses due to a difference in heat temps. I dont nkow too much about them so any advice would be great.
Thanks in advance.
https://www.sau.com.au/forums/topic/265391-aftermarket-xenon-hid-kits-for-r33/
I have used HIDs in all my cars over the past few years and never had any discolouration problems at all.
Heat is what causes discolouration and you are more likely to get it from high wattage halogens IE: 50w onwards.
Do the HID's get hot and do most come with that UV filter?
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
