Hi guys some of you might remember last year we did a photo shoot a nite one with as many cars as possible with a professional photographer which went well but alot of SAU members missed out due to the date and time...... this time it would be similar except weekend day time and a couple of models to brighten up a few things... if your keen let me know depending on the numbers i can figure out a cost factor which wont go on time as oppsed to last shoot .. bear in mind one car will have around 200+ shots taken ..
here is a few shots of what he can do models are selectable so you can say if you want blondes or brunettes choice is up to each individual ..
Enjoy
Vish
Mods please move if in wrong section...
Edited by 53XYN
https://www.sau.com.au/forums/topic/265566-photoshoot/
Looks like stock leather seats with aftermarket head-rest pillow to me.
lol inside joke, i just spent a whole day explaining to Taz that OBX makes special aussie-bum spec buckets for those who can't fit into regular bucket seats.
https://www.sau.com.au/forums/topic/265566-photoshoot/#findComment-4536212
wtf guys, they don't all have to be stick insects... a bit of respect wouldn't go astray :ninja:
I am actually going to have to agree with Rev here... I don't see a probelm with either women. They look like they are comfortable with themselves and it appears that they are having fun.
Nice car BTW Vish.
https://www.sau.com.au/forums/topic/265566-photoshoot/#findComment-4537305
lol i'm just messin... they actually look pretty hot with clothes on, its just the bikini top shots that bring focus to the wrong parts. sometimes the imagination is better than reality, and its up to the photographer to utilise parts of both to bring out the best in someone.
https://www.sau.com.au/forums/topic/265566-photoshoot/#findComment-4538030
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
