Hey all
normally i wouldnt post something like this, but i know some of you may know what the deal is with changing from side feed injectors to top feed? has anyone in sa actually done it?
whatsisname is the man to ask! but i thought neo 6 were top fed anyway?
but it is more costly changing to top fed because you need to get a fuel rail made! but i went for it because i thought maybe later on i might need to go for bigger injectors and there is a bigger variety of top fed then side fed
Edited by nos man
i need 1000cc injectors and i cant find any for the RB25
the other option i was thinking was maybe going with RB26 fuel injectors and getting a RB26 Fuel Rail to match but i dunno if that will work either!
1000cc are pretty big injectors! aiming for huge numbers or something?
but rb26 injectors should fit into neo 6 motors! no need for fuel rail i don't think but they're like 440-480cc injectors?
edit. rb25 neo, rb20 and rb26's all run top fed injectors! it's the r33 rb25 that runs side fed
Edited by nos man
I got 870cc Bosch Siemens Injectors forsale. $600
Came out Phu's old 34 im pretty sure.
Edit, 34's are top feed anyways.
Edited by Luke_ENR34
yeah the supercharger im getting is 800 hp with a 1200 CFM on it :thumbsup:
are you taking the piss Cara or you are seriously thinking of putting a 800 hp super charger on your car?
ive seen you drive NA and i can asure you with anything over 300 hp you will become a statistic.
please be careful.
RB25 NEO's run top feed high impedance injectors. i would suggest wiring in a resistor pack from a GTR and running low impedance injectors for a couple reasons. Because the injectors you use will then be the same as the GTR injectors there was more of a market than the high impedance injectors used on the RB20's and therefore should be slighly cheaper. Also low impedance injectors are a lot easier to control when running low duty cycles.
If you are going to be making 800hp then you will need to run an after market rail (probably 14mm injectors as well) and you will have to upgrade your fuel lines from the tank, it'll be expensive but i'm sure you weren't expecting it to be cheap.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
