Hi guys,
Ive been busy grabing up goodies for my 33 GTS-t and will be looking at getting a tune within the next month or so. Is there anything that really stands out you would recomend getting upgraded before the tune that i havnt covered.
Car Stands at the moment
1996 R33 GTS-t Series 2, 91,xxxkms
3" Turbo Back exhaust
CoolingPro Return Flow FMIC
Bosch Intank Highflow fuelpump (unknown HP)
Apexi Power Intake Pod Filter with Alloy Intake pipe
600cc rb25det highflow injectors (yet to arrive)
Apexi Power FC (will be installed with tune)
GReddy Profec B spec II EBC (will be installed with tune)
Hypergear 450hp T3x Highflow Turbo (will be purchasing shortly and tune will be conducted after run in)
If there is anything you feel i shoudl take a look at before doing the une that woudl save some extra work later please let me know :) Thanks for any helps guys i appreciate your experience and expertise :thumbsup:
I would say, cold airbox with cold air feed.. but seeing as you have the Blitz Style return flow, id say, stock airbox and a decent panel filter :thumbsup:, rather than the Pod.
But thats just me.. and plenty of others agree.
This part about the turbo
"will be purchasing shortly and tune will be conducted after run in"
What run in are you talking about?
You have a fresh motor?
Nice mod list, turbo IMO lets it down a little.
Also find out 110% what the fuel pump is before you start, saves hassle later
Gotrice - Thanks yeh i have been trying to think of a way to make a cold air intake for the pod without cutting holes, so far jsut using standard "snorkle" to funel air to the pod may modify airbox later.
R31Nismob - No motor is not fresh but the turbo will be built and need a run in 1000k ish before the oil flows properly then gets a dyno tune.
I know the trubo lets it down a little but it seems great value for money and does save any hassle on upgrading manifolds and the such and helps keep things looking standardish haha
As long as i end up with over 200rwks il be satifyed for now :thumbsup:
Edited by Keeffy
The airbox would probly have to be fairly well sealed for the snorkle to achieve alot. The way i see it, the stock box sucks air through it because it has no choice, but an unsealed cold airbox wouldnt be as efficient because its clearly going to suck air from the easiest location.
Oh, and listen to R31Nismoid.. he knows what hes on about!
Thanks guys im jsut going of what hypergear has informed me and they have been making these turbos for quite some time.
"As for the run in, The bearings needs to wear in about 1 thou to allow more oil flow"
hey dude, good mods, yes the turbo is decent bang for buck... im running one now at bout 15psi-17psi.... they have pretty good torque.... i got a little over 400 on status's dyno....
why not spend ~$200ish more and get a z32 to finish off... because i imagine in ur current setup the afm will be ur limiter.... get that and u'll be @ about 230rwkw... without it, probably 200ish because the afm wont be able to handle it....
gl with it....
Coilpacks huh thanks for the heads up, looks like i have a little more time up my sleeve, gogin to wait till hypergears bigger rear highflow turbo is in stock inless i can find a cheap r34 turbo op6 rear housing haha :D
Thanks agian guys keep them coming.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
