Hey Guys,
My car seems to idle fine (albeit a little high, but not concerned) but my car is not really running as well as I thought it would.
If revved up, and the throttle is let go, the car will stall. Boost gauge gets to around 3psi, and no more (vacuum leak?).
The car is an auto, has a blitz BOV and t3/t4 hybrid turbo with FMIC.
Is it that I just haven't retuned the car? Or should it run slightly better anyway?
https://www.sau.com.au/forums/topic/266354-huston-we-have-a-problem/
hey... ease up... i had a t3/t4 jobby on my rb25 and gave it a rough tune... it worked well enough.. i used a safc 2, a big fuel pump and pressure reg to pump as much fuel as the stock injectors could handle... then leaned it out with more boost.. dodgy as fu(k i know... but it worked... and the car is still running, somewhere... the turbo let go though.
Crikey! I didn't realize skyline forum dwellers could be as bad as VN owners on the Street Commodores forum. But Nismoid, that was uncalled for, and a little unfair. Perhaps even just plain f**king rude. I have the engine in my VS, the car in a million peices and I can't just take it to get tuned until the thing is roadworthy. I don't have a factory bov, the halfcut I got never came with one! Always check your purchase out hey?! I didn't realize this was a spelling police forum either!
NZM.031 - I dont have the problems with the guards and piping, but I think you guys may be on to something with vacuum leaks, they are so ongoing! Can you get aftermarket plumb back blow off valve to suit the same flange as the blitz?
I do have an 044 external pump and a large pick up pump. Surge tank and rising rate reg. Is there any vacuum lines I need to be carefull of? Things easy to miss?
...ANYWAYS...
What engine is it? Standard ECU?
High idle usually means an air leak.
The stalling after revving will most likely be the BOV.
If you rev it less does it still stall, or does it run really shit with black smoke out the zorst?
Half a million VLs cant be wrong lol.... nah.
Better than it going in a another VL (leh) lol, or it being put in a 240z and desicrating that (whats wrong with the L series engines anyway? ;)).
Just mating a nice engine with a nice body. Seen worst acts in skylines anyways... :)
It doesn't blow too much black smoke, only when revved up, and from the smell, I am 99% sure its unburnt fuel. And it doesnt really run to shit, pretty smooth, and doesn't stall when revved lower.
So BOV? Can I block it off and give that a run, or do I really need a plumb back to do diog? I will get it tuned, but I wont the nagging issues that I may have missed sorted first. SO, just looking at things I may have missed before hand first.
get some detergent and water in a spray bottle and apply liberally to all piping.... then rev car... you should be able to see any leaks clearly.
black smoke is fuel... and nissan stock ecu's are fairly rich
bov-wise.... if its stalling, then you need it plumbed back...
Thanks mate, you have helped alot already, I owe ya big time. I knew the smoke was fuel, you can smell it, but i don't want to turn down the reg lol.
Missed that part - put the factory reg back on there if you dont need injector headroom
just another thing that can go wrong that if it isnt required - stock is fine.
FYI - i ran 350rwkw using a factory reg, as have countless others that made even more :)
Replace all vacuum lines even if you think they are in good nick. (they are cheap).
Try it, you will be amazed at the difference it makes.
I recently tried this on my Stag! helped Immensely.
Good luck!!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
