My mate's 808 is a great example of a nice street sleeper, sure the whole old Mazda rotary has been done a lot but...
Smoothie wheels, red/white wall tyres, rear venetians and a sun visor.
Oh, and it also runs 10's with a full interior and numberplates - not bad!
That's awesome! :-)
  • Replies 200
