Guest RedLineGTR
pull the dash out disconnect the wires and uncrew the back panel..check the bulbs and see if u can find them at your local store...u can use blue caps on stock bulbs to get a nice effect abit of muckin around and u'll get thier...sorry havent done it myself but seen some images on the net and instructions how to do it didnt seem to complicated.
inast u ricer :) ... looks good .. i wish mine looked that good ... apex gear looks good too :D ... i think that what it looks like is that the numbers instead of being white will be the colour of the bulb ... however i'm thinkin that it won't be as bright so u will have to get really bright bulbs ... i want to do this too ... please someone do it and take some pics :)
A mate has had the bulbs changed in his car and it looks great.
Basically it looks totally stock when the lights are out. But at night when you turn the lights on, everywhere on the dash where it's normally white light, it turns to blue.
Looks very good and is easy on the eyes at night.
J
AutoSalon magazine ran a DIY article on this topic, they did it in a 180sx i believe.
Basically, rip out dash, cover all bulbs with AutoMeter or similar brand globe cover things, put dash back in, too easy.
bulbs r shit.
with the EL dask kit u have brightness control and u can go from blue to green backlit in 5 shades between.
i was thinkin of doing this to go BMW style or something.
ALL ORANGE.
but nv had tthe guts to go tamper with it
what abt the dash board buttons such as aircon control unit the lights and etc
possible to make those orange too?
tahnksss
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
