Guest RedLineGTR
pull the dash out disconnect the wires and uncrew the back panel..check the bulbs and see if u can find them at your local store...u can use blue caps on stock bulbs to get a nice effect abit of muckin around and u'll get thier...sorry havent done it myself but seen some images on the net and instructions how to do it didnt seem to complicated.
inast u ricer :) ... looks good .. i wish mine looked that good ... apex gear looks good too :D ... i think that what it looks like is that the numbers instead of being white will be the colour of the bulb ... however i'm thinkin that it won't be as bright so u will have to get really bright bulbs ... i want to do this too ... please someone do it and take some pics :)
A mate has had the bulbs changed in his car and it looks great.
Basically it looks totally stock when the lights are out. But at night when you turn the lights on, everywhere on the dash where it's normally white light, it turns to blue.
Looks very good and is easy on the eyes at night.
J
AutoSalon magazine ran a DIY article on this topic, they did it in a 180sx i believe.
Basically, rip out dash, cover all bulbs with AutoMeter or similar brand globe cover things, put dash back in, too easy.
bulbs r shit.
with the EL dask kit u have brightness control and u can go from blue to green backlit in 5 shades between.
i was thinkin of doing this to go BMW style or something.
ALL ORANGE.
but nv had tthe guts to go tamper with it
what abt the dash board buttons such as aircon control unit the lights and etc
possible to make those orange too?
tahnksss
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
