Selling my OEM R34 GTR intrument cluster.
In perfect condition.
Reason for selling: I sold the car with the Nismo 320kp/h cluster
Will accept best offer or $300.
you pay postage.
Photo's if required [camera temporarily not working]
Will be sent in the Nismo Box for protection.
Thanks
https://www.sau.com.au/forums/topic/266984-original-r34-gtr-instument-cluster/
