the s14 caliper is average compared to r33 etc... just something to bear in mind.
hmm,. I didn't know that. is that why you used 33 skyline gear on my silvia? :) thanks big boy.
you can also pick up second hand 996 cup car calipers very cheaply.
I have 997 cup car brakes on my GTR. Initial purchase was fairly cheap, rotors are semi easy to find second hand and adaptors we make ourselves.
Problem with them is the pads are so expensive and very limited to pad suppliers.
The 996 ones might be better though.
None what so ever.
They are pretty large and open across the bridge but the 997's have mounting points a very long way apart. I know John has been using them for a while too and has had no issues.
Before I start, apologies for all the questions but rushing in and asking later has already caused a few headaches :happy:
OK - About to get an AP Racing kit for the front - AP CP 6600 Caliper with 330mm DBA 5000 rotors and Ferodo 2500 pads. Rears will be standard S13 for now.
AP Racing CP6600 Caliper Information
Before I do get this: Issues with this set-up, what else will be needed?
Do I need to upgrade my master cylinder and brake booster?
Will the S13 SR20DET master and brake booster handle it well enough? I dont know what master the S13 has standard.
Are the GTR master cylinder and brake booster sufficient?
Will upgrading the master and brake booster provide better braking ability?
Will upgrading to these items whilst using the standard rears cause bias or other issues?
Do I then need to upgrade my rears to R33 GTST or R32 GTR items? is it better to run R32 GTR rears if I get the R32 GTR master cylinder or wont this matter.
Thanks in advance guys :P
1.Do I need to upgrade my master cylinder and brake booster?
2.Will the S13 SR20DET master and brake booster handle it well enough? I dont know what master the S13 has standard.
3.Are the GTR master cylinder and brake booster sufficient?
4.Will upgrading the master and brake booster provide better braking ability?
5.Will upgrading to these items whilst using the standard rears cause bias or other issues?
6.Do I then need to upgrade my rears to R33 GTST or R32 GTR items? is it better to run R32 GTR rears if I get the R32 GTR master cylinder or wont this matter.
1. yes, i was running out of both air and pedal was travelling a long way with the 15/16ths master cylinder and standard S13 booster. GTR item is much larger, GTR top standard S13 bottom
I Now run a GTR booster and 1inch master. Sooooo much better.
2. see answer 1
3. see answer 1
4. see anwer 1
5. no, hasn't on mine and i have gts-t 2 pots on the rear.
6. see answer 5
Thanks.
It is much larger. Any dramas with fitting it up in place? Is it a direct bolt in, do all the lines match up or does it require some modifications?
In relation to Question 5, your gtst 2 pots are the same as the gtr 2 potsI believe, which the GTR master normally comes with. If I run the s13 standard single piston rears will this cause problems with braking?
Thanks.
Remember my car runs a RB25, i also use a custom inlet manifold, it sits very close but doesn't touch :banana: I imagine you'd have more room with an SR?
Yes it bolt straight in, used the vacuum line i had in there.
The booster is only there to provide assistance, its the brake master cylinder that does the work via your foot. Now a 1inch item from an Australian R31!!
I couldn't answer if the single rears would upset the brake balance, if it does ( which i suspect it won't) it all comes down to pad choice again. Put it this way i use the same pad front and back, i have no braking issues :)
Here's a little gem for you. It's a rule of thumb, not exact, but for every 1kg change of rolling mass ( ie going to a larger, heavier brake rotor) a 1kg rotating mass increase is equivalent to an increase in the cars weight by 10kg. So, if your brake upgrade adds a measly 2kg of rotor weight on each front wheel, you've effectively added 40kg of mass to the car.
The ONLY reason i changed to a 324mm rotor up from the 280mm was the rotors were under legal size, so i thought i'd give the caliper some extra mechanical advantage with an increase in rotor size. The above example is what happened to me, but the extra performance of the rotor/pad combo, more than made up for the "increase in weight".
Some food for thought.
Hey mate, is the R31 MC non-ABS? That's an interesting choice, I'd be keen to see if that's the case as I imagine they'll be a hell of a lot cheaper than an R32 GT-R N1 MC
I couldn't be certain, i found it in a wrecker, most of the engine bay had been ratted, the MC was all that was left, but from memory, there was no ABS- don't quote me :)
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
