h i here is a list of parts i no longer need . all parts are in sydney.
contact by pm.
original throttle body and tps from my R33 rb25det top condition $100 ono
2000 wrx air box and snorkel top condition $130 ono
Greddy throttle body Adapter for greddy plenum $100 firm
exeddy sports organic clutch for rb25det ,working fine you can see where it was slipping from having to much hp i used this for 6 months and then got a better one great for 260 kw atw. $150
r33 gtst gear box mount good condition $30
r33 gtst engine mount 1 only good condition $20
intercooler 76x600x300 from shift performance top condition no damage at all good for 300 + kw $200
s/s intercooler piping 2.5inch this will suite a greddy plenum set up there is also one from the turbo with bov mount for a r33 gtst $120 ono
silicone joiners and clamps $60
2 3.5 to 2.5
1 2.5
1 from throttle body to 2.5
1 original elbow 2.5
the intercooler ,piping and silicone joiners can be sold as a full kit for a greddy plenum set up
Edited by WARLORD
https://www.sau.com.au/forums/topic/267320-r33-parts-and-one-wrx-air-box/
is the intercooler a stealth?
If it is how much for the whole package?
sorry intercooler is sold,but all other things are still for sale
thanks princess01
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
