Hey guys i have a r33 gtst.. When i'm 4th gear and going 60kms it slowly revs up and then when it hits 3,500rpms it just revs out with no power....
When changing gears it feels like the clutch is staying on for about a second and then it comes out..
The boost gauge is just sitting on 0 PSI.
I took the turbo off last week and put it all back on, I've triple checked everything though.
One of the oxy sensor wires looks really loose on the plug, could that be it?
Thanks, Alex.
:laugh:
it kept comming off but its on now.
i only took the one pipe off and it looks fine, its not making the noise it was when it last came off but i am hearing a noise sounding like its coming from the air vent. sounds like a gas leak?
yeah vacume lines seem fine but ill have to look agian in the light, when the piping came off it was making a wistle nosie but was doing the same as it is now so your prob right.
i only touched a few things under the engine bay but.
    • Just had this happen to me too.  R32 GTR.   Also broke "just before going out onto the track" - someone up there is looking out for us... Very scary since I was about to do a narrow street course with zero run-off and curbs everywhere. Many people on here upgrading to billet uprights and R35 bearings?   Or buying new OEM knuckles?  I am not keen to replace with another s/h 30 year old fatigued part.
    • Top off with distilled water and see what happens. If you keep losing coolant then you know to start looking.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
