Pretty certain they have inertia locks. So the belt locks if the car stops suddenly, or the belt tries to reel out quickly.
You need to make sure the belt is "up the right way", and just pull slowly / gently on the belt to get some length.
https://www.sau.com.au/forums/topic/267678-seatbelts/#findComment-4564503
what kind of belt is it?
"klippan" inertia reels have a ##/## relating to the degree vertically and horizontally
ie a 90/90 will be straight upright
39/90 is perpenducular to the ground but 39` from horizontal
ensure it is pretty damn close - you generally have 5` of tollerence
stick it in a vice at the right angle and clamp the bit where the mounding hole is tight (not the actual reel obviously) you should if a klippan or autoliv have a clear window on the side and see the bearing near an orange tag.
the bearing should sit so the orange tag doesnt sit in the reel teeth - generally it will be loose and not sitting still
the idea of the orange bit is so when the car is on an angle the belt locks - there is also an internal inertia lock what when the belt spinns too fast w/o the angle trigger, it will lock under centrivical force
get some silicone spray with a tube nozel and give the belt a good spray through the webbing wound round the reel (wascaley wabbit)
if the orange trigger is released then all you need to do is pull up on the webbing with your girly arms till you get an additional 4 inches or as much as you can - you cant break it - this is what it is designed to hangle, allow the reel to retract *VERY SLOWLY* till the inertia lock releases and you can then freely pull the belt. you now have your belt back. put a block of wood behind the reel of if you had yellow tags which came with the reel - put them back on and do not take off until the reel is installed (this stops it retracting too far again - if it does you remove the wood or tag and have a good foot of belt to play with to release the trigger again) .
But for the love of God do not tug on it when it is not EXACTLY in the right spot or you need a new belt - yoursecond chance of over and you spend more $$$
or take it to people who install belts for a crust
Willshires at 466 south road in marleston will do it for ya - i used to work there some years back
its a 5 minuite job free of charge.
let me know how you go
Dan
Edited by 910trx
https://www.sau.com.au/forums/topic/267678-seatbelts/#findComment-4564786
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
    • Man, I miss having a phone that fits into my hand!
    • The speed this thing starts up is making me want to replace my old one. Though my old one immediately kicks into reverse camera as soon as reverse is engaged, it's clearly not part of the android system. For everything else though, starting up, connecting to hotspot, opening maps, starting music in spotify is easily a ~2 minute affair.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
