Hi everyone, I was wondering what sort of an ordeal it would be to change the springs/shocks in my 32 GT-R, considering I have basic tools and would be doing it off a jack? Do I require special tools of any kind to get the job done? I really want to have a go at doing this myself if possible since finances are tight, but I gotta say I do enjoy learning as I go with these types of things! Any help from you guys would be much appreciated :)
Yeah u can tackle it at home but make sure u use a jack & good quality stands.
You will also need a spring compressor of some type.
And when completed a wheel alignment.
Cheers & have fun.
Ah Thanks Yld-Chld. Will I need a spring compressor for the back? This is the end in need first of all... Also, I'll probably be getting the springs/shocks together, so if I am swapping the whole show in one piece, is the compressor still required? Hmmm, better start scouring ebay for one just in case!
http://www.monash.edu.au/muarc/VISU/reports/jacks.html
read this and realise how few of these people used jack stands. I have seen plenty of jacks (bleed down) or someone come and twist the handle while fiddling with it and drop a car by accident. not good.
http://pandora.nla.gov.au/pan/49480/200504...eport_jacks.pdf
1.5 hours???
Did ya stop for lunch as well???
I recently had a small problem with my Bilstein Shocks, broke the top clean off while many miles from home.
Rang a couple of mates and within no time had sourced a set of coil-overs to go in my 32 GTR.
We had the old shocks out and coil-overs installed, in Hungry Jacks carpark at about 11pm in Hobart CBD.
Took us all of 25minutes I reckon.
Did the fronts at home the next day, by myself in less than an hour.
GTR struts would have to be by far the easiest struts I have ever replaced in my life.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
