Thats only if its the Neo engine,
Non-Neo (R33 S2) alot more work to get the Power FC working
Dezz what engine is going in?? and what loom you using??
Pretty sure she's got a Neo engine...So the 34 GTT pfc is the go?
If so, anyone got the link to this pin54 trick?
and no idea on the loom sorry...
You CAN use the R34 GT-t unit on the s2 R33 engine, but it takes a fair bit of internal modification. I've got it running in my car, so I know - Mark @ Hills Motorsports can do the mods, and has done mine, Duncan's, and about 10 others. I *think* it's around $700-odd for the modifications to be done (assuming you already own a PFC).
Mark told me he can get pretty much any RB-engine PFC running any RB engine, so give him a call... (02) 9899-9962.
As for the secret tweak to pin 54 (or 51?), do a search in this section for "Secret Squirrel Tweak" posted by EGA41T or wolverine
https://www.sau.com.au/forums/topic/267921-stagea-powerfc/#findComment-4568387
nup,
plug and play
depends on the actual series build of the ecu itself. not the neo engine or non-neo stuff.
my feb 97 S1 ran with an R34 GTT power-fc. plus the secret squirrel trick
https://www.sau.com.au/forums/topic/267921-stagea-powerfc/#findComment-4568394
nup,
plug and play
i don't think so.....
1st the injectors r in the wrong way for a feb 97(ALL S1 stagea need mods done to work!!) have studied for 6 weeks about this!
Dezz if you need any info pm me.
https://www.sau.com.au/forums/topic/267921-stagea-powerfc/#findComment-4568884
sir
I can assure you it depends on the ecu model and NOT the neo or non-neo engines
due to differences in ecu models there are differences in loom wiring
series 1 has 3 or 4 different ecu's, some work with the power-fc others need more configuring. mine was pretty much plug and play
yes, certainly other mods are required to get a S1 and a R34 GTT P-fc to work.
https://www.sau.com.au/forums/topic/267921-stagea-powerfc/#findComment-4569126
S1 stagea came with the S2 R33 rb25det (ALL OF THE S1 Stagea need mods for the R34 Gtt PFC to work!!)
S2 stagea came with the R34 neo rb25det (if the car is a manual, R34 Gtt PFC will work with the pin 51 trick)
But because its going into an R32 your A/c might not work, which is another problem with the PFC working on the S1 stagea (Needs mods to the PFC to make it work), could be the same for the R32?
https://www.sau.com.au/forums/topic/267921-stagea-powerfc/#findComment-4569298
yes all of the S1 stagea's come with the S2 R33 RB25, but tangles is correct in saying that in the S1 there were 3 different ecu pinout configurations used, they all are still the same S2 R33 ecu internals with the R34 style plug, but the pinouts vary between the three.
one of the configurations was pritty much the same as the R34/S2 stagea pinout. tangles must be lucky enough to have this one. also according to fast one of the S1 ecu variations was only used for about 3 months of production.
https://www.sau.com.au/forums/topic/267921-stagea-powerfc/#findComment-4569390
Sounds like I'll have to get the engine number and put it into fast to find out what series this engine is...?
you cant run engine numbers through fast. but if you post up a pic of the engine there are a few sure ways to tell if its a neo engine or not, even if the plastic cover is missing.
https://www.sau.com.au/forums/topic/267921-stagea-powerfc/#findComment-4569394
Pretty sure its a neo...
Car is an auto by the way...auto will be built (not sure on specs) but definitely not going to be standard....
aircon/heater etc will probably be removed too...
https://www.sau.com.au/forums/topic/267921-stagea-powerfc/#findComment-4569925
Thats funny because i too have a Feb '97 Stagea (Same as Tangles) and i had to mod my Power FC to make it work.??
must be just my stagea then, i got all my info from the jap stagea service manual.
And the S1 service manual ecu pinout shows mine (09/96 - 08/97 engine harness no. 24011-0V100) same as mine and Tangles, but for some reason he didn't have to mod his Power FC??
https://www.sau.com.au/forums/topic/267921-stagea-powerfc/#findComment-4569937
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
