Any of the current quad core Intel CPU's matched with 4Gb RAM and an intel chipset based motherboard will do the job. If you're doing all your stuff in the box you won't really have to worry about the quality of the convertors on a audio card, just make sure it has solid ASIO drivers.
  • Replies 492
Posted Images
Just got Operation Flashpoint : Dragon Rising (was a big fan of the original)
Game RULES.
Anyone interested in doing 4 man co-op? Remember this game is 1 shot one kill so you'd need headset and mic and a decent connection to ventrillo :stupid:
-D
EDIT - Sorry guys, I posted this in the wrong frigging thread. Mods please move to Computer Jargon :D
that is pretty awesome Steve! is that main guitar actually a recording of your own, or something you've created entirely with the NI guitar rig?
Cheers. :(
All the guitar and bass tracks are my own recording, the drums are samples that I programmed. Guitar Rig isn't a guitar sampler or synth, it's just a guitar amplifier simulator/modeller and effects processor.
Craig, how'd the halloween sessions go last night mate?> i should of asked ya to record the mixes!!!
Hey mate. Was a very big night.
music didnt stop till my sister got alittle pissed of :( around 4am.
Really good night. Few quiet ones from now on I think.
First night using a DJM700. what a mixer mate. Real nice. and a CDJ400.
Edited by PREISS
haha awesome!
shit, a 700 (digital 600 basically) and a 400? thats a couple of $k right there....!!!!
i'm definitely considering 400's when its time to venture into CDJ land, the 1000's are just so bloody expensive... but probably worth every cent though.
that 700 must have some f'ing great features
had the DJM400 mixer. plus 700. two CDJs100s and a CDJ400 on the desk. I liked looking at the setup more than playing it haha.
yeah real nice features. Some I didnt wanna play around with too much at the risk of being too messy.
Might be selling the DJM400 soon. great mixer. good features but really wanna save for a 800
yeah i know what you mean - thats the thing when i've used the big pioneers - i just play with what i know, faders, EQs and maybe a little effect here and there. But i have no idea how to use the samplers etc. Sucks because you're not really using it to its full capabilities!
pioneer gear holds value very well, you should get a decent $ return when you sell your 400
not really at this stage. one mate of mine (whos supposed to be coming with me to that dubstep night) would have probably been keen, but he's moving back overseas for two years shortly. But i will definitely ask him!
Another one of my tracks, really rough at the moment because I got bored with it. I do like some of the riffs in this one though....
nice pentatonic solo midway
makes me wanna jam with ya, but im nowhere near as good as u are lols
-D
Cheers :P Not my fav part in there and I'm no good at it anymore either...LOL!
problem for me is i used to do jazz/blues piano as a kid so my brain is stuck in the open e pentatonic most of the time haha
-D
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
