  • Replies 52
sorry to hear mate, was a feeling a bit strange when i read the title, i remember seeing your car at Roe Street CPP on the weekend as i parked there too
good to hear you've got it back mate better than nothing right?
hope insurance helps mate cheers
im sorry to here this but its the sad thruth that it happens all to often..my friends r8 ute was taken the same way recently and then used for ram raids around perth......i sleep with my f**kn keys....these days................im also thinking that a alam with the four pin code would b a great investment as then if they get ur keys they still cant start the car with the pin lock on....very sorry to hear again i hope u can get here back on the road mate...
suxxs nuts man, is it a write-off?? at least they didnt wreck those sex wheels.
i always sleep with my keys, have them in my top draw i also have a flip knife under my pillow, have had for years now!! gl stealing my keys!
hope it turns out good for you, just remember, dont except the first offer the insurance company gives you, theyll try and give u the least amount possible!
until recently i worked at both fowles and pickles auctions dealing with all insurance co's..so i would see an average of 20 new wrecked cars each day....i left that job to start my own smash repair company, so my advice is pretty accurate as i know how each insurance co thinks...i know their different repair/write off percentages etc, buy back rules etc..(apart from me "inspecting" every wrecked nice car in the yards ha ha..i bought wrecked s15 too...
anyway...
1. if thats not written off then i will be speechless.....rule of thumb is rear quarter panel damage = massive job to replace., thats without rear suspension etc...
2. who u insured with?
3. insured value? agreed value or market value?
4. where is car now? cannington compound?...cops have to do forensics/dna, then insurance assessor has a look..
and my neighbours camry was stolen 3 weeks ago from burglary too...(churchlands area).car found in cannington next day, no damage at all....obviously needs locks/keys changed (780 for just the parts without labour...car still not been worked on
by allianz repairer....allianz say no lock kits available (i called toyota and they are in stock) lying cuunts)...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
