yeah...ive gotta get off my ass and drive up to sydney and start having a proper look...look on the net is all very well and good but....cant plonk my ass in seats or try on suits/boots/gloves etc with out actually being there.
  • Replies 240
Posted Images
Copied from Ando
2.3 Main roll bar: Structure consisting of a near-vertical frame or hoop located across the vehicle just behind the front
seats.
2.4 Front roll bar: Similar to main roll bar but its shape follows the windscreen pillars and top screen edge.
looks like if I want to run ill have to hack my dash :D
So basicly im out unless I get a dedicated track car
re the 2nd fireproof layer all you need is cotton undergarments, no need for the expensive thermal gear. 2 layer suit is a better idea but if yo ualready have a 1 layer cotton stuff will do.
Copied from Ando
seats.
Yeah we are tyring to ascertain if we can run the front roll cage down the front and curved around the dash. BUT reading the above info i found it would suggest a front roll cage has to follow the A pillar all the way to the floor without deviating more than 70mm from the pillar.....
longs underneath will be fine, esp for AASA. Double check with them if you are concerned but the whole concept is cheap, safe racing without needing over the top rules.
around the dash is not possible in a skyline/silvia while meeting cams regs. you need to stay net to the a pillar, and only bend once. which is very sensible from a safety perspective, I reckon those thin tube jap cages thst bend 3 times will fold like paper in a real crash
cool cool...can we get away with front legs like the ones in the pic i posted?
Edit - In the MRA regs it says that pre-2000 cars can have an alloy cage...yet weve now been told that we need a CAMS aprroved cage...I dont know of any CAMS cages that are alloy
Well if Dunc is correct we should be able to get away with a cage as per your pic andrew... check below guidelines for full cage. One bend only coming down infront of dash should be ok..... SHOULD BE...
no they are just falling in line with cams rules as the earlier comment said (must comply with the rules are the time).
At some stage (maybe pre 2000?) alloy cages were fine, you just need to poke around older race cars. I'm sure AASA are trying to give older cars (there are heaps in sheds around the country) a place to race cheap. In fact CAMS allow any material or design you want if you have it structurally certified by an engineer ($5k plus), the rules they publish are just the cheap way to meet their minimum requirements
This is the current cams regs which you will have to comply with http://www.camsmanual.com.au/pdf/10_gen_re...dule_J_Q309.pdf. Regarding the front legs it specifically says "Front roll bar: Similar to main roll bar but its shape follows the windscreen pillars and top screen edge......The front leg of a front roll bar or of a lateral roll bar must be straight, or if it is not possible, must follow the
windscreen pillars and have only one bend with its lower vertical part"
No way you can do that in a skyline when the dash is 20cm deep at the bottom of the a pillar. And there's no point having a roll cage thats not safe anyway. If its a race car cut the dash, its easy and cheap.
I guarantee if you are racing the car a cut in the dash will not be the last damage you do to it
This is true!!!
The prev owner did the chop and cut with the mx5's dash and did a pretty good job.
Also seen some vids of him racing in QLD....very close racing and some panel rubbing!
hahah this is door to door racing remember....if you are not willing you get close enough to rub panels you might as well stick to super sprinting - its the getting close/direct competition that is the core of the excitement of racing. If you aren't willing to get close you will get eaten alive by your competitors who are.
And once you've tried it anything else on a race track will seem a little second rate.
btw if you do ever want to put the car back to stock after acin git (no way lol) you can always but a new dash for 100-200. nothing compared to the cost of a tyre let alone a full safety prep for racing
ya i know.... time to take a cement pill and start hacking at the interior.... not fussed about panel rubbing, look forward to a little car to car 'Morse code' :D You can pick up S13 panels for cheap cheap
Same Spando, mx5 parts are cheap as and mx5mania is 2 mins from my oldies :D
I just cant wait to feel this new rush from motorsport which duncy and brad etc talk about!
yeah...i think ill wait 6 months before taking to my dash with a saw....ill make sure everything else is done on the car first...and knowing me the car will break somthing before too long anyway
Sooo cage will be the last thing I do
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
