yeah...ive gotta get off my ass and drive up to sydney and start having a proper look...look on the net is all very well and good but....cant plonk my ass in seats or try on suits/boots/gloves etc with out actually being there.
  • Replies 240
Posted Images
Copied from Ando
2.3 Main roll bar: Structure consisting of a near-vertical frame or hoop located across the vehicle just behind the front
seats.
2.4 Front roll bar: Similar to main roll bar but its shape follows the windscreen pillars and top screen edge.
looks like if I want to run ill have to hack my dash :D
So basicly im out unless I get a dedicated track car
re the 2nd fireproof layer all you need is cotton undergarments, no need for the expensive thermal gear. 2 layer suit is a better idea but if yo ualready have a 1 layer cotton stuff will do.
Copied from Ando
seats.
Yeah we are tyring to ascertain if we can run the front roll cage down the front and curved around the dash. BUT reading the above info i found it would suggest a front roll cage has to follow the A pillar all the way to the floor without deviating more than 70mm from the pillar.....
longs underneath will be fine, esp for AASA. Double check with them if you are concerned but the whole concept is cheap, safe racing without needing over the top rules.
around the dash is not possible in a skyline/silvia while meeting cams regs. you need to stay net to the a pillar, and only bend once. which is very sensible from a safety perspective, I reckon those thin tube jap cages thst bend 3 times will fold like paper in a real crash
cool cool...can we get away with front legs like the ones in the pic i posted?
Edit - In the MRA regs it says that pre-2000 cars can have an alloy cage...yet weve now been told that we need a CAMS aprroved cage...I dont know of any CAMS cages that are alloy
Well if Dunc is correct we should be able to get away with a cage as per your pic andrew... check below guidelines for full cage. One bend only coming down infront of dash should be ok..... SHOULD BE...
no they are just falling in line with cams rules as the earlier comment said (must comply with the rules are the time).
At some stage (maybe pre 2000?) alloy cages were fine, you just need to poke around older race cars. I'm sure AASA are trying to give older cars (there are heaps in sheds around the country) a place to race cheap. In fact CAMS allow any material or design you want if you have it structurally certified by an engineer ($5k plus), the rules they publish are just the cheap way to meet their minimum requirements
This is the current cams regs which you will have to comply with http://www.camsmanual.com.au/pdf/10_gen_re...dule_J_Q309.pdf. Regarding the front legs it specifically says "Front roll bar: Similar to main roll bar but its shape follows the windscreen pillars and top screen edge......The front leg of a front roll bar or of a lateral roll bar must be straight, or if it is not possible, must follow the
windscreen pillars and have only one bend with its lower vertical part"
No way you can do that in a skyline when the dash is 20cm deep at the bottom of the a pillar. And there's no point having a roll cage thats not safe anyway. If its a race car cut the dash, its easy and cheap.
I guarantee if you are racing the car a cut in the dash will not be the last damage you do to it
This is true!!!
The prev owner did the chop and cut with the mx5's dash and did a pretty good job.
Also seen some vids of him racing in QLD....very close racing and some panel rubbing!
hahah this is door to door racing remember....if you are not willing you get close enough to rub panels you might as well stick to super sprinting - its the getting close/direct competition that is the core of the excitement of racing. If you aren't willing to get close you will get eaten alive by your competitors who are.
And once you've tried it anything else on a race track will seem a little second rate.
btw if you do ever want to put the car back to stock after acin git (no way lol) you can always but a new dash for 100-200. nothing compared to the cost of a tyre let alone a full safety prep for racing
ya i know.... time to take a cement pill and start hacking at the interior.... not fussed about panel rubbing, look forward to a little car to car 'Morse code' :D You can pick up S13 panels for cheap cheap
Same Spando, mx5 parts are cheap as and mx5mania is 2 mins from my oldies :D
I just cant wait to feel this new rush from motorsport which duncy and brad etc talk about!
yeah...i think ill wait 6 months before taking to my dash with a saw....ill make sure everything else is done on the car first...and knowing me the car will break somthing before too long anyway
Sooo cage will be the last thing I do
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
