now this has been goin on for afew months, and knowing that my old radiator had a slight leak, i didnt think much of it.
anywayz last week i bought a 40mm aluminium radiator from just jap and did a full collant change.
after topping up, bleeding it properly etc i decided to check the level afew days later. overflow bottle was between MAX and MIN, so i topped it up thinkin that maybe i didnt fill the radiator to the top durin the change.
just noticed today theres no water in the overflow bottle !?
i am not leakin any coolant, il take the car for a good drive then look under the car and nothin is dripping, hose clamps r nice n tight. doesnt look like anything is coming from the water pump either
engine oil is clean as, did a service 4 weeks ago and the whole amount of engine oil did come back out (after 6000 odd kms), no signs of water in the oil
what could it be?? any help fellas would be great !!
https://www.sau.com.au/forums/topic/268269-r33-overflow-bottle/
Although you have checked when you turn the engine off you may be leaking water from one of the hoses under the plenum. We have a problem with an rb26 where it doesnt leak when driving however approx 3-4 minutes after switching off we get a leak- not much it would seem to be coming from a line and the leak is dependant on the radiator pressure (as the pressure drops it leaks).
Get some cardboard and when you next stop slide it under the engine you may have a similar problem.
Just a wild question - How did you bleed it?
Reason why i ask, is because in the manual it states to bring up the engine temp up and turn the heater on 32*celsius and all.
However some mechanics claim its best done when the engine is dead cold, with the engine off.
I have a similar issue that seems to have gone away now after i bled it over and over. The other thing to notice is that the overflow bottle has a hole in the top bit, so maybe while driving it manages to escape through there?(highly doubt it tho)
i blead the system from the little screw on the top of the engine
had it undone until the car got to operating temp and the lil bubbles stopped comin out. didnt take longer then afew mins to blead it
if thats wrong, should i do try bleading it again? how exactly do i do it? while the car is hot, or start it when cold and let it idle until at operating temp while the screw is undone??
thanks
ok i herd that my problem could be the radiator cap
i noticed when i put it on the my new radiator that it still had abit of movement and wasnt sealing 100%, so i bent the little tabs on the cap abit so it can tighten up once i do it up
now i also herd the pressure rating could be wrong?
im goin to buy a new radiator cap, wot pressure ratin do they hav to have?
buy a nismo one? (but very $$)
or just ask for a stock replacement?
  • 3 weeks later...
I had a similar problem and found it was a hair line fracture in the cooling line going to the turbo the little one at the back of the block.
Sorry not very descriptive I'm not a mechanic, if you want I can take a picture and post it for you.
  • 4 weeks later...
Just replace the cap with an OEM item. The Nismo Items are good, however you have to consider that they are rated higher pressures, around 18 psi i think? As opposed to the stock which is 15psi? This will cause MORE strain on the radiator hoses, considering most skylines run the factory hoses which are rusty and "weak" and as a result, the Nismo cap MAY cause the pipes to burst/leak.
Ideally if you changed the hoses to SAMCO or some other stronger item, the Nismo caps would be better.
If you can, try opening the cover over the waterpump. If any sign of rust, then leaky waterpump!
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
