yer those sp1's look pretty phat
guess its hard to go wrong with te37s
It's pretty easy to go wrong with TE37's actually, if you get weak offset they'll look very average.
na, TE-37's look shite on gts-t's / gtt's, not enough offset to get depth into the spokes. GTR only, same with LM-GT4's
Buy lower offset....problem solved
i agree totally dezz... just as long as those who go ahead and buy the lower offset realise that they may have clearance issues and are gonna have to allow for that in tyre selection, suspension and possible guard mods :closedeyes:
dayum thats hot. black and red is a awesome colour scheme. i wish i had a red skyline :P
you can.... its a respray :)
Hi there for a cheaper option I would recommend the koya drifttechs which are a multifit option 5stud for both nissan and holden and a 4 stud for 4x114.3
driftek's are 4x114.3/5x114.3 and will suit most jap cars, and falcons... commodore's are 5 x 120
I love my xd9's :)
If I didnt want to spend a fortune on wheels, I would buy some drifteks/Rotas, the rotas are better they have more concave, nice offset will look fantastic
or buy 2nd hand jap rims for the same price.... i got my professors for 2300, flawless, with 2k worth of rubber on them
*pic of blags car removed cause this post will be way too big anyway*
looks sweet as dude.... knock out some camber on the rear and it will peform/look better again!
No, its just when people put weak offsets on GTS-t/GT-t's are too weak to do any guard mods or put any effort into making good offset wheels fit. Low offset (or GTR offset, god i hate that term!) TE37's can easily fit a R33/R34, check out the S13 below. It runs 17x9.5 +12 front and 17X10 +18 rears and a S13 has much smaller guards than a R33/R34
+1 the term gtr offset shits me too as it only looks good on gtst's
and that s13 is phat... te37's will never look good without any guard work, that's the nature of the beast, but when done well they look HAWT!
JMS r33 looks good
only bad thing for most people is that r33's have those crappy wheel arches that don't look right with a flare, unless you are willing to get your rear guards flared and resprayed so you can fit some low offset wheels
hey blags
apart from the 20mm spacers did u have to do and guard mods on ur 33
cheers Nick
They didn't require 20mm spacer to fit, if that's what your asking.
The rear guards have been rolled.
The front had 20mm spacer too but with no camber they were scrubbing no matter what I did. I have taken the spacers off till I get some camber arms
i have incubus Paranormal 18# black one but they look so good it is not funny i dont have a pic of my car with them on but here is a link to the wheels http://superbuytires.com/Incubus/Paranormal/
If you guys are talking about the picture I posted up then yes, they are CST Hyper Zero's but it is an R33 sedan. Maybe the eyelids on the headlights put you off?
na realised it was a 33, but i thought they were weds sa-70's with a huge offset.... my bad
hey dude
wat are your size/offsets that dish on the bac looks sick
DO NOT put those on a skyline!
not even a holden deserves that sort of punishment!
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
