The car is just for street i dont want hard suspension because the hume highway, canterbury rd etc... are a f**ken pain in the ass !!!!
you dont have to have hard suspension to improve your cars performance. search it out on here
I did mention i have an aftermarket ECU (computer) in my first post, just didnt mention which one. And i rather not say as not to get laughed at :laugh:
i laughed harder at you for saying that than anything you coulda done to your ecu. sounds like you're all about perception rather than performance mate....
Are there any other bolt ons other than throttle body, plenum, fuel rail, injectors and up the sparking package. Can i just buy all the parts, bolt em together then swap em into the car? Or is it a little more than that?
none of the above bolt ons will likely give you much of a gain without upgrading your turbo.
dont take offence mate, im really trying to help ya here -
my suggestion would be if you just want a high dyno number then go in with your car as is and tell that to the dyno operator and he can easily alter some numbers to get you a figure you're proud of.
if you want more power, then have a search on here about what other people have done, then ask some questions. you'll get a lot more respect that way
magnets for the fuel lines
big wing
vortex generators
gauges
vinyls
neons
etc
but seriously, your next step is probably a decent ECU (sounds like you have a piggy back or something) and then start sorting out the intake cause the standard R33 intakes are shit!
Hey, dont worry mate i dont take offence.
I know everything that needs to be done but i like talking about it as it helps me make a better decision.
Thanks for all the input everyone. The way i word things isnt great either but all of you get what i mean :D
Hopefully you will all see me at a track day soon and we can tear it up :(
Cant wait.
Edited by R33LOD
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
