Im looking into getting new tyres as my rears as quite worn especially after doing a level 2 driving course.
My step dads making a fuss saying i have to get the same tyres as the ones i have on the front. The front tyers i have on are Nankangs ive had them on for over a year and still plenty of tread left on them
The rear is my second set..had nankangs which were crappy on the rear and wore them out now have worn Austyre or something cant quite remember.
Im asking if it will make any difference putting different type of tyres on as they have different tread pattern????
someone please shed some light on the situation
okay well i quickly looked it up in google and most people have said that its fine aslong as they are the same size. So the brand/tread wont make a difference, just got the make sure i get them aliigned.
yes its fine. The only time it would cause an issue is on the track where they will warm up differently. Even then its not a massive problem as front and rears warm up differently anyway!
it depends really but since its an rwd i would make sure u got good ones on the back. I got 235 potenzas on the front and hancook 265 on the back. NO issue at all, just make sure that they are pairs :D
My Dads the same "must have same tyres front and rear, blah blah blah" yeah maybe thats what they had to do in the olden days, when they had to have the same tyres front and rear whilst dodging dinosaurs on the way to the shops!
^^^+1
I had this issue when my Potenza RE-01Rs wore out at the rear. I replaced them with Toyo Proxes.
The difference in heat build-up was such that the Proxes felt mushy. When my Potenzas wore down at the front & replaced with Proxes (as a matching set), everything was sweet again.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
