from the little info we have I would say it's a poor tune. simple as that. the car should not run poorly over a change in altitude of 400m.
hmmm, as stated my STI did the exact same thing, different car different tuner?
If it is a temp and barometric pressure issue, it could be far more than 5% if none of it is corrected, however 10% still shouldnt be enough, however i have seen it happen without the use of an air temp sensor, basically in summer blowing black smaoke, and lean in winter.
crap, so how is that fixed?
cheers
how? with a real tune & a real ecu - ie go back to the PFC or get the link installation sorted and tuned properly
if its got a map sensor it should be setup accordingly, along with air temp sensor to correct itself
* WINNER *
* WINNER *
yeah but it had a power fc in it before (tuned by another tuner) and it ran sweet till it came to queenstown, then again ran like crap
Im not sure if you can do anything about the barometric pressure compensation, as that should be built into the firmware of the ecu, however the IAT table makes a massive difference. From what i see a lot of tuners dont think outside the box and realise just how important having an Air temp sensor, and the correct corresponding numbers in the table.
Any competant tuner would usually turn away any map based ecu if it lacked an IAT sensor... well around here anyway.
Couldnt agree more, but ive seen tuner do installs without them enough to know it happens around here, usually the excuse is the owner didnt want to spend the extra for the sensor and install! Crazy.
hey there,
just figured out the backfire/hesitation is when boost starts building when its cold, when the engine isnt warmed up
also there is no cold start up set on the LINK either yet?
ideas??????????????????????
Are you anywhere near rips, i would take it to them. If you can put up screen shots of the settings in the software then it will make it easier.
hey, no which sucks, about 15 hrs away, bummer though i sponsor Robbie Ward at RIPS, ha.......
will try getting that info
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
