Hi all,
I'm looking for a set of R34 GTR rims in excellent condition, preferably with rubber and located in Sydney so I can pickup and pay cash.
If you have a set please give me a call on 0434 929 257 and let me know how much your after.
Thanks!
Edited by KR4-GTR
https://www.sau.com.au/forums/topic/268609-r34-gtr-rims/
It doesn't help, but I thought i'd give you a free bump because you are looking for an excellent set of wheels.
If you want to pay $18,000 for my 34gtr wheels, you will also get a r32 gtr as a bonus? haha jks.
https://www.sau.com.au/forums/topic/268609-r34-gtr-rims/#findComment-4634546
still looking guys! had a guy that i was going to buy a set from but doesnt look like he is going to come through!
as presumed, no luck in that space!
still looking - cash ready right now! :)
Edited by KR4-GTR
https://www.sau.com.au/forums/topic/268609-r34-gtr-rims/#findComment-4646726
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
