Gearbox out of '96 R33 in good condition
Asking $1350 ONO
3" Dump/front pipe with hi-flow cat
Asking $250 ONO
RB25DET engine out of '96(s2) model R33. Done just over 100K, in good condition. Made 178rwkw on 10psi with powerFC.
Asking $2250 ONO
Also got Jim Berry full monty(4000lb clamp pressure) single plate clutch with just over 2000 km's on it - near brand new.
Asking $700 ONO
pics soon...
PM or call 0433 180 120
Cheers,
Pav
Edited by pavel
What is wrong with the gearbox?
Noises?
Any crunches at all?
K's on the box?
Nothing is wrong with the gearbox, no noises or crunches. Just over 100K's on it, thanks.
Edited by pavel
haha need 2 b quiker :whistling:
lol yeah i kn,,5 minutes earlier and i woiuld hav got it..but its alright, i found a cutom front pipe and custommed the rest myself to fit, responds so much better
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
