  • Replies 52
The cooler kit cost me $1500 delivered. Although it's a bit more expensive than the equivelent HKS item in my eyes after seeing the quality of the ARC cooler it was money VERY well spent. The ARC cooler is not as big as the HKS Type S in size but it's power rating is more than enough for me. I'd be max 250kw.
Speak to dAVE in the Vic section for more details on them.
Abo Bob - I know this may sound strange but after I put the cooler in I took it for a quick spin and it seemed to come onto boost with a lot more of a punch. I mean it wasn't boosting harder but just seemed to come on with more of a surge and there was a little bit more noise.
It's hard to tell what difference it made as I had the Power FC, FrontDump pipe and Bleed valve installed at once so it's now running 10psi after a dyno tune.
The power is pretty good and the delivery is awesome but I still want more. I don't really know how much more I can do without looking at a turbo upgrade though.
Dyno Sheet -
Have a look how restictive the stock dump pipe is! -
You can see round the flange how small the pipe joining into it is. Around 2" would be my guess compared to the 3" I have on now.
Guest Robo's
Put some more boost into it. I repeatively done back to back runs from 10-13psi and we were gaining 10-15 up high, but midrange was like 20rwkw more, thats were you feel it. Just tell ICE you want some more boost. If you want more power, this is a fix until you get used to it.
Had the car checked on the Dyno on the weekend, turns out was running far to lean at high boostRPM. Looks like my fuel pump had had it :cheers: I need a Bosch 975. Best price so far is $280. With it running a little richer is now making 190kw but boost curve drops at high end. Need to fit a HKS EVC to fix that. With a new controller should be around 200kw. Will post a dyno sheet.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
