Oem Standard Gtr Injectors
By Nightmare_mistress_R33 · Posted
I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger? -
If you are getting that sort of fuel usage, you might as well be back in the stagea
Looks good mate, those stainless lines must be a bastard to do neatly. Better get it to a track again sometime soon, I'm doing to Wakie day next Wednesday to see if the v37 likes cool weather better than hot weather....
If you've got spark, and you've got fuel, it needs once last thing to go vroom... Have you compression checked the motor?
I confirmed cylinder is TDC. harmonic balanced is old but rubber looks good. Night before last I took the balancer off and used the crank mark to confirm timing. Plugs are brand new bkr6e at 1.1ish
