Lads,
Gonna grab a EBC this weekend. No idea what to buy to be honest. Happy to spend $500-700 bucks i guess but have no need for fancy f**kin screens and gizmos.
I hear the dual solenoid EBC are the way to go. Why is that exactly? What is the advantage technically speaking over a single solenoid? Or a boost tee for that matter.
Im not going to buy a Boost Tee thing as i hear they can spike fairly dramatically and i dont plan on replacing the turbo, thus ive disregarded the idea. Going to run 10psi as apparently its fairly safe. Ive heard i can run 12 max, its tempting, but im not game. Already told my wife ill do no mods to the car .... i managed to do the below on the sneak..
Mods:
R34 SMIC
3 INCH NISMO EXHAUST HIFLOW CAT
JJR SPLIT FRONT/DUMP PIPE
K&N HIGHFLOW PANEL
STOCK BOOST (although im running the high mode constantly..)
168 KW ATW so far.
Cheers
https://www.sau.com.au/forums/topic/269081-r33-gts25t/
$700 on a boost controller is insane, there are cheaper options for sure
check out ebay and look for a 2nd hand unit if you want
just check their feedback etc. but for std turbo a single solenoid unit is fine
ive ran 12psi or 0.85 for about 4 years now on the same std turbo
210,000km and still going fine. my recommendation if you have $ to burn
apexi powerfc, hand controller and powerfc boost control kit
unbeatable
https://www.sau.com.au/forums/topic/269081-r33-gts25t/#findComment-4582987
unbeatable
You have had to PowerFC running things including boost since the beginning. maybe thats why its lasted?
https://www.sau.com.au/forums/topic/269081-r33-gts25t/#findComment-4583019
not sure
first off i did the boost hack (i made the howto doco)
then i did the hks EVC at 0.85 bar
then did the pfc boost kit at 0.85 bar
std turbo 210,000kms and still goes well
its been to drags, motorkhana, plenty of street abuse
https://www.sau.com.au/forums/topic/269081-r33-gts25t/#findComment-4583090
mate get a turbotech one. it holds boost, but if you want to be in the safe place, go for the blitz sbc or the greddy profec spec b II, i was using iton the stock turbo and i compared it to my turbotech one, i relased it had a bit of lagg and spikking, the electronic one boost will come on earlier and hold better.
Cheers,
https://www.sau.com.au/forums/topic/269081-r33-gts25t/#findComment-4583115
not sure
yeah i know and its a bloody good hack i must say. Certainly made a noticeable difference especially around town. Considering you have to be virtually full throttle passed 5k to even seen/feel the second stage, i rarely ever did. Simply concept too. I wired up a switch but ive left it on permanently.
perhaps i shouldnt worry to much about the car holding up then. Ive got 70k and its seen no abuse from me or previous owner in Japan. Serviced every 5k or less etc etc.
good to hear anyway.
https://www.sau.com.au/forums/topic/269081-r33-gts25t/#findComment-4583635
get a turbotech manual boost controller of ebay, this would be the ONLY MBC id use. theres a big 80+page thread on here just search for it. + if your hiding mods from your wife i dont think your gonna go over 200kw & 12psi anyways, ive only ever heard problems with this MBC over 15psi, yet some people run close to 20psi, so you will defo be safe
this will do the job for under $40 http://cgi.ebay.com.au/Turbotech-manual-tu...93%3A1|294%3A50
https://www.sau.com.au/forums/topic/269081-r33-gts25t/#findComment-4584024
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
