hey there my fellow skyline enthusiast,
i have a r33 s2 gtst... and it is relatively stock..
however, it had an aftermarket bov which was attached one of the intercooler pipes..
the stock bov was still in place but was blocked off (top hose was cut and a screw put in there)...
i removed the aftermarket bov and put the stock pipe back in to see if there was any difference..
besides getting a little flutter action.. i noticed my car was a bit more responsive.. no change in boost level or anything...
and today i got a spare hose and reconnected the stock bov... my car was current boosted at 9psi..
so went for a drive.. and and gave it a bit of gas and saw my boost gauge hit 15psi... and i it wouldnt rev past like 4500rpm or so... im assuming i hit the fuel cut at boost levels that high...
so my question is... how did reconnecting my stock bov bump up my boost so dramatically?
https://www.sau.com.au/forums/topic/269337-bovs-and-boost/
What he means is the actuator working? It sounds like it isnt because your boosting continually and that seems to be the actuator not responding to whatever limit the boost controller is set to.
Connecting the BOV doesnt effect your boost level, your boost controller does that and if you have not connected it you will just continually boost.
EDIT I just read your last post.... you havent connected the boost controller, it is next to the pwr steering res.
https://www.sau.com.au/forums/topic/269337-bovs-and-boost/#findComment-4585979
im not running a boost controller man... im using a hks actuator to control my boost... it was set to 9psi before i took out the aftermarket bov... and wen i took the aftermarket bov off and reconnected the stock bov... the boost went up past 15psi... i dont have the boost solenoid either... just actuator to intercooler pipe..
i have readjusted my actuator to 10psi now... boost comes on much earlier now.. and kicks in harder..
just weird how it jumped up so dramatically...
Edited by banhzSIIR33
https://www.sau.com.au/forums/topic/269337-bovs-and-boost/#findComment-4586083
The std bovs are quite good. Block the little bleeder hole in them and they work as well as a tight 'good' aftermarket.
I blocked my std bov off some time ago as I don't see the need for one + I prefer the slight dose noise over an airy whosh bov sound.
Edited by SLAPS
https://www.sau.com.au/forums/topic/269337-bovs-and-boost/#findComment-4586302
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
